1 (edited by jip 2017-04-14 19:42:55)
Topic: UFX+ installation without USB (over Thunderbolt 3)
I tried to install an UFX+ on a Macbook Pro 2016 (Touchbar) under MacOS 10.12 (Sierra), with an Apple Thunderbolt 3 to Thunderbolt 2 adapter. The UFX+ is not recognized: "host" led is blue, and TotalMix and RME Settings do not launch.
I tried to install the same UFX+ on an older computer over USB 2: the installation and the flashing went without a glitch.
I tried the installation again on the new Macbook Pro 2016, without success. Even after reboot, nothing happened.
At the moment, I haven't got a Thunderbolt 3 to USB 3 adapter to test: does one needs to plug the UFX+ via USB for installation? What about flashing? (I do not need to do it know, but I would like to know for the future.) Then, I would prefer to use the UFX+ over Thunderbolt, as I read that the performances are better: is it right?
But for know, I would appreciate some help.
Best,
Jip
Re: UFX+ installation without USB (over Thunderbolt 3)
Did you set the interface mode in the display menu to Thunderbolt?
I have got no access to the UFX+ until Tuesday, but if I remember correctly, the interface mode was "automatic" on the LCD display. I was unable to change it (it was grey). I unplugged the USB cable, so I expected the Thunderbolt to work with the automatic mode... I will try again and let you know.
You can not change it while any interface cable is connected and working already.
5 (edited by jip 2017-04-16 14:51:29)
This information would be a nice addition to the manual:
This would mean that the device would be working... However, no software (TotalMix and RME Settings) launched. Could it be a MacOS 10.12 (Sierra) problem?
Do you thing it is possible to install the UFX+ without USB? I.e. over Thunderbolt only?
Sure. We do that all the time. Which TB driver did you install?
I tried today, and I must confess I totally overlooked that:
Indeed, I went to the website, and I taught I installed the driver for the UFX+. Indeed, I installed the USB driver without further noticing. (I also installed the flash update tool, which is for both USB and Thunderbolt.)
I know see in the manual also that there are 2 drivers...
After installing the Thunderbolt driver, everything works perfectly, as it should, as usual with RME products.
Thank you for your help, and sorry for the noise. Really.
