Topic: Connecting both a Steinberg UR824 and an Audient ASP800 to a UFX
I finally got my UFX (after a disastrous demo with a MOTU 1248, but that's another story), and Im super excited to get started with it. However, I also possess a Steinberg UR2824 and an Audient ASP800, and I plan to continue using both of them (I'm now in possession of 20 total pres!). I'm curious to know if anyone here has any prior experience connecting these two particular pieces of gear to the UFX, and what route you went, or if anyone has any advice having had similar experience connecting other pieces of gear.
Basically I'm curious to know if I should connect each device individually to the UFX's ADAT and wordclock I/O, or if I should connect them in serial as UFX>Steinberg>Audient and let the Steinberg handle the connection to the Audient and pass that whole package on to the UFX. No matter what, if Im not mistaken, I'm going to have to clock everything to the UFX somehow, so I guess basically at this point I'm essentially trying to figure out what specific method I want to use and the pro's and con's of each method.
Anyway, thanks for being an awesome community and thanks in advance for any help you guys might be able to provide!
Cheers!
