1 (edited by OmegaStylesBC 2017-04-26 02:57:34)
Topic: new Intel build + UFX, questions before purchase
Hello everybody! I initially asked this on Reddit and was told to check out these forums for more detailed/experienced answers. I've used Mackie interfaces for about 9 years and finally decided to upgrade, so to speak, to an RME UFX. I've been reading so much and checking older threads, but nothing specific to the boards and/or setup I'll have.
I am building a new PC after all this time, specifically for music production. I wanted to share my current build, in the process of still being purchased and also a small list of possible motherboards and would like any feedback as to whether there are any known issues with these motherboards, or any other parts I've listed, and the RME line of interfaces. I may use Firewire, which I have a (Syba SY-PEX30016 3 Port TI XIO2213B Chipset), but I may just stick to USB.
Anyways here is my build list, along with possible motherboards. I'm sorry if this is a repeated question, but for $1,500, I really want as much information as I can get before purchasing. THANK YOU for any insight!
- Intel Core i5 7600 (I'll use only the integrated graphics, no dedicated card)
- Windows 10 (which I hope to have installed on a Transcend 128GB 2.5" Solid State Drive)
- Western Digital BLACK 1TB 7200 Rpm Internal HD (for sample storage)
- EVGA Supernova 550W 80+ Gold
- 8GB of 2133Mhz RAM from Corsair, haven't figured out which specific model yet
(possible Z270 motherboards I'm looking at buying)
- GIGABYTE GA-Z270X-UD5
- MSI Z270 GAMING PRO CARBON
- GIGABYTE GA-Z270X-Ultra Gaming
- ASUS TUF Z270 Mark 2
Any other heads up you guys can give is appreciated! The UFX will be my first "real" pro level purchase, so I want to be as informed as possible.
Hope I provided enough information for you! Thanks
2 (edited by knuckle47 2017-04-26 05:13:00)
Re: new Intel build + UFX, questions before purchase
The following free advice is only that..and as you've probably heard, opinions are like rectal apertures...everbody has one.
I can happily spend your money but in a practical situation, you might look at the i7700k.  There is a difference in cost but futureproofing has some merit. My last 5 computers had a running life of about 6 yrs each ( yes, my first was an IBM XT with a 10mb Corvus hard drive) before seemingly bogging down by improvements elsewhere.  I am currently using the ASUS TUF Z270 Mark 1 and it is a great motherboard. The construction is terrificly solid.
One nice option that I know little about is the Optane Memory Module that will be here in a few days.  Reports say it will store and load your most used program overhead very quickly....for what I've put into this new build the extra $40 is minimal and the results appear to be quite promising. Whether or not it has a place in our application remains to be seen but it seems to really do well. The m.2 slot is on the ASUS board.
You can always add another 8gb strip of ram if your daw demands it. My biggest problem with boot drives under 256gb is that they get loaded up with updates, adobe, other drivers and "stuff" and there is a point when it tells me there is not enough room on the drive to perform some task and it stops any update in its tracks.
My choice with the z270 I have is that I wanted Thunderbolt...don't fully need it, but it's out there and I want to try things these days that I was unable do to in prior years.  If I can recommend a case...look into the Nanoxia Deep Silence series.  They are quite heavy by other standards but I have not seen a case so well built, solid and AMAZINGLY quiet. If you use a water pump with radiators, the ASUS board needs the larger case or the radiator infringes on the edge of the mobo.
Most importantly,  there are guys here with extreme knowledge of these things so my findings come only from trial and error over the last 34 years.  I'll say that I am very happy with the performance of my newest computer build over my 6yr old 2600k. The variables in the bios allow for some detailed setups.  There has been 2 updates already there.  This water pump cooler and two built in fans keep this running under  25° C and the fans spin under 500rpm so they are quiet quiet!
Hope some of this helps
EDIT: I am reading that FireWire I'd likely obsoleted...FYI
Babyface Pro, UFX+ via Thunderbolt, Win 10, Cubase 9.5 Pro, Asus Z270 i7700k Guitarist-1961
knuckle47, I want to thank you very much for that detailed reply. I actually bought a Rosewill THOR V2 case when Newegg had a super special going for it for $70, after markdown & rebate. It's a huge case, with great fan control. Water cooling scares the crap out of me and is out of my league lol
I don't plan on any OC'ing, just wanted a solid, strong CPU, just for audio. I'm squeezing pennies I guess going for i5 for i7, but a few users on other sites have said in the real world, there isn't "that" much difference between i5 and i7. it's all good though in that department.
my biggest thing was just finding a motherboard with solid USB drivers, I guess Intel drivers are what I'm looking for, because I've read 3rd party USB drivers usually cause problems with interfaces & their drivers, etc.
I don't know much at all about navigating the BIOS, so I guess I'll be trying my luck with a motherboard that works with the interface from a driver/bios POV and then when it comes to buffer sizes/DAW settings, I could probably handle it from there.
It's cool that you mentioned your ASUS Mark 1, I've continued searching tonight and found the Mark 2 (a bit cheaper) that I'm adding to my list also.
Thanks again man!
Don't go for a reduced chipset. Use the more powerful Z variant even if you do not overclock.
Dont overclock. More wear on components and likelyness for less stability. Also produces more heat.
When selecting the CPU look for the base clock, as you wont reach turbo frequency. For reduced latency for processing programs you will optimize BIOS and OS settings which prevent core parking and energy saving so that you will eventually get permanently approx 100MHZ above base clock permanently but not more.
Good is to get a CPU with at least approx 3.5 GHZ base clock so that you have enough single thread performance.
Use a CPU with hyperthreading, with most applications you get a performance win.
6-core CPUs are nice.
If you plan to do do video editing then I would go for 2011-3 boards with double mem bandwidth.
I would not rely on internal GPU. It uses memory from your usual DRAM and esp on laptops the builtin GPU leads to clicks and pops even when using asio driver for audio playback. I regard these solutions as cheap to to save costs and IMHO CPU and GPU should use their own memory not to block each other when accessing RAM.
Rather than taking any internal GPU or old passive card I would go for nVidia card with zero fan feature. Either Maxwell or current GPU family. Even if it costs 150 on top. Some video editing SW can even make good use of GPU power if available. The fans wont blow under 60°C and this you wont reach with nowadays nVidia Chips with Office or Cubase.
Take a mainboard that offers also ×4 lane sockets for high performance add on cards. If you use the x16 sockets of graphic cards then its possible to impact your graphic card to run with x8 instead with x16 lanes. Sometimes sockets are sharing lanes with other components on board. You should check this upfront in the handbook of your mainboard.
If you take SSD, and you should do, then calculate that you need to leave free 15% of netto capacity to ensure long and sustained read and write performance. Taking the bigger SSDs ie 512 instead of 256GB has besides capacity the advantage of higher I/O bandwidth.
For Ultra performance take M.2 based SSDs and/or even split Os/Programs, Sample Libraries and User Data between 3 different SSDs or a combination of SSDs and Harddisks to have multiple times the Sata bandwidth available. IMHO cheap and solid is a combination of 512GB SSD and 1-2 TB 7200 U/min Harddisk for user data and on top 3-4 TB harddisk for backup.
Best add NAS to have also backup external from PC. Cheap solution is to use Sata 6 hot swap case in PC to make weekly backups and after backup you eject disk take out of pc and store in another room.
A reliable backup solution is Macrium reflect for doing disk images. User data / projects I also mirror to backup drive to have data accessible in native format shall backup sw have issues to read data.
Shall usb performance have issues as all bad things can happen if you use different USB devices, then you can use an USB3 controller with from RME tested Fresco chipset. I use successfully the model which has 4 USB controller mounted, one for each of the four ports.
5 (edited by ramses 2017-04-26 12:02:52)
I am using a supermicro server mainboard with very good success, still win7 to avoid any surprises by the non controllable amount of updates (win10 "windows as a service" approach).
http://www.tonstudio-forum.de/blog/inde … mponenten/
Before installing your system I recommend to deactivate 2 things in the BIOS (if supportedby your BIOS), as it usually brings more hassles by more complexity compared to the real benefits for the user which I regard around zero:
- UEFI
- Secure Boot
In the article above you find references to related articles to this particular system in terms of BIOS Optimization and optimizing CPU cooler and blowers of the system.
The only thing that I am missing is thunderbolt as I have the UFX+. On the other hand USB3 comes very very close to thunderbolt performance in terms of latency reported by the ASIO driver. M.2 SSDs could be upgrade by PCIe cards, but performance wise I see currently no necessity for my setup.
http://www.tonstudio-forum.de/blog/inde … cks-de-en/
Now that is a detailed reply...!
With regard to water cooling...it is a very simple sealed system that mounts onto the CPU and has a loop going to the radiator.  I've had to think about it twice in 7 years. Once when I installed it on the 2600k and once when I ordered a new one for this i7700k.  If you see it in your future plans, don't let anything else intimidate you....there is nothing to it
Very good point Ramses makes with the video card versus on board graphics.
Good luck.
7 (edited by OmegaStylesBC 2017-04-26 23:00:15)
I just wanted to say bless you guys for ALL this information and the TIME you guys took to help me out! Thank you!
A strong line of thunderstorms and possible damaging winds are headed my way soon, so it may be a couple days or so before I can report back and researching.
I did want to mention it makes a lot of sense about using a dedicated video card rather than relying on the built in graphics, which results in higher RAM usage, but I've just read a few comments about people graphics driver causing issues with interface drivers, etc.
That will give me something new to look into after these storms pass.
Another thing I just read last night is for these newer motherboards that have only USB 3.1, interfaces & devices that have only USB 3.0 apparently don't work or at least don't work too well with USB 3.1 ports.
I'd assume plugging USB 2.0 into 3.1 would be the same until they update drivers, etc. Although these boards have a couple 2.0 in that case. So just a heads up to those that may be trying to run USB 3 into a 3.1 port. I guess you could also get a USB 3.0 PCI-e hub.
As for storage, I was planning putting my .wav samples and libraries on a WD Black HDD 1TB. My programs, OS and other apps would be on Transcend SSD. I was looking at 128GB, but I may just get a 256+GB SSD based of your reply Ramses.
Again, thank you fellas for all the knowledge. Bookmarked & saved smile
I have narrowed my new list of boards down to these three:
1) ASUS ROG STRIX Z270H GAMING (has thunderbolt 3 built-in and USB 3.1 Gen 1 & 2)
2) ASUS TUF Z270 Mark 2
3) ASUS PRIME Z270-K
If you get a board with thunderbolt 2 then you dont need an additional adapter to connect a recording interface like UFX+.
Don't be frightened to get a graphic card.
I used MSI GTX 970 and now Gtx 980 in my silent PC build. Even when gaming it reaches merely 54°C so that all blowers on this card are always off. Its the 4g gaming model. Now newer cards are out with more power. Take one of the smaller models not or not so overclocked.
But they need to have the Zero Fan Feature explicitely listed in product description.
