Topic: Using the UFX along with a USB turntable?
I have recently been gifted a USB turntable and was hoping to find a way to use the monitors connected to the UFX to listen to records without loading a DAW session and having to use an aggregate device.  It works fine this way, just takes longer to load than I hoped.
Is there a way to use totalmix to route or loopback the usb turntable outside of a DAW?  That way I can save it as a session/snapshot when I want to listen to a record.
Re: Using the UFX along with a USB turntable?
No, unless the turntable has an alternative output (analogue or digital)
Could you somehow get the USB Turntable to feed your computers digital output and then feed that digital signal back into the UFX for monitoring?  The computer would need to be on, but you would not need to have any other software open or use aggregate devices to my knowledge...
cool
2x SSL Alphalink MADI AX
