Topic: Fireface UCX + OSX Sierra: Crackling audio after a few minutes
Hi everyone,
No matter what I try (changing buffer size, sampling rate etc.), when I use my Fireface UCX, the entire audio starts to increasingly crackle after about 3 minutes of activity, ending up in total noise which makes the interface unusable. Happens every time, although I suspect the crackling comes more quickly the busier my arrangement is (still happens in very light arrangements too though).
I've updated drivers, no change.
I use:
MB Pro late 2016
OSX Sierra 10.12
Fireface UCX
Firmware v46
Driver v3.01
Ableton 9.72
Would appreciate some help - at this point, I'm considering to return the Fireface as its obviously quite a disappointment (more so as I bought into RME given the otherwise good talk about driver stability).
Re: Fireface UCX + OSX Sierra: Crackling audio after a few minutes
Have you installed the 10.12.5 update yet?
It's supposed to fix some audio problems, and fixes some 30 holes in the OS...
And have you tried adjusting latency in Ableton's setup?
