Topic: ARC USB: please make "MUTE" work across grouped channels, as DIM does
Hi -
New ARC USB customer here, VERY happy. Using it with UFX.
I mainly monitor in 5.1, and so I have analog output 1-6 in a fader group. 1-2 are "main" speakers, since we can only Assign stereo pairs as "mains". This is fine, as the gain controls track any volume moves.
- Wonderfully for me, the "DIM (Main Out)" control honors the grouping. (Maybe under the hood, it's just doing a "-20dB volume shift")
- However "MUTE (Main Out)" control only mutes the Assigned/declared master speakers.
- Also: Talkback activation does NOT dim the other channels, only the ones assigned as "Main Out"
Thanks for considering it! It's a lightweight way of supporting multichannel control room setups without having to build the entire set of surround sound monitoring controls.
2: 2018 i7 Mini, 32gb
ProTools 2023.3, Live 11
UFX, FF400, Babyface
