Topic: Mac OS 10.12.5 doesn't working
Hello, Please help me!!!
I have Mac OS 10.12.5  and Babyface Pro with 3.01 Driver and it working well till today and during morning (GMT+3) , after doesn't.
I re-install OS clearly from scratch, and this doesn't help at all, but Driver 2.17 work nicely !!!
My question is What Happen ??? and how I can back to 3.01 ???
Best Regards.
Re: Mac OS 10.12.5 doesn't working
Any chance you did an update to OSX?
Or your Mac is set to auto update?
The latest update that went out was GateKeeper definitions update IIRC. But I don't see any connection with the latest Babyface driver.
Unless it has to do with driver signing?
3
We have 10.12.5 with latest patches as well and there is no driver signing problem visible.
What means 'doesn't work'?
What Apple computer is this?
In System Report / Software / Extensions what is shown for ->FirefaceAudioDriver?
Is there some usueful info shown in the log of the console? Usually if a driver is denied there will be error messages.
Matthias meant System Report / Software / Extension / RMEFirefaceUSB
5 (edited by dpoul 2017-06-08 21:15:39)
System Report tell that driver is installed and that I get it from verified developer , but anyway total mix doesn't load properly and doesn't react on any action !!!
System is clearly installed ,all hd's are fully formatted.
Computer is iMac  2011 model.
Please open Audio-MIDI-Setup to check number of inputs/outputs -  should be 14, if not, BF Pro could be in CC-Mode.
7
Additionally it could be that you have something from Avid/ProTools installed so the BF Pro will work competely, just TM FX doesn't open.
8 (edited by dpoul 2017-06-09 05:52:20)
14 IN/ 14 OUT,  No, Avid/Pro Tools doesn't installed!!!
With driver 2.17 it work now, but some time earlier it also work with latest 3.01!!! What Happen ??? I don't know!!!
9 (edited by dpoul 2017-06-11 09:39:45)
Problem doesn't solved, Today it repeated again!!! Please Help Me !!!
Totalmix FX is unresponsive.
10
- open the Activity Monitor
- double click on the TotalMix FX process
- in the new window, click on 'Sample'
- Save the Sample Text and send it to us
Sampling process 715 for 3 seconds with 1 millisecond of run time between samples
Sampling completed, processing symbols...
Analysis of sampling TotalmixFX (pid 715) every 1 millisecond
Process:         TotalmixFX [715]
Path:            /Applications/Totalmix.app/Contents/MacOS/TotalmixFX
Load Address:    0x100000000
Identifier:      de.rme-audio.TotalmixFX
Version:         1.42 MAC OS X (1)
Code Type:       X86-64
Parent Process:  ??? [1]
Date/Time:       2017-06-11 19:36:47.561 +0300
Launch Time:     2017-06-11 19:34:12.652 +0300
OS Version:      Mac OS X 10.12.5 (16F73)
Report Version:  7
Analysis Tool:   /usr/bin/sample
Call graph:
    2798 Thread_77497   DispatchQueue_1: com.apple.main-thread  (serial)
    + 2798 start  (in TotalmixFX) + 52  [0x1000015c4]
    +   2798 NSApplicationMain  (in AppKit) + 1237  [0x7fffa5adae0e]
    +     2798 -[NSApplication run]  (in AppKit) + 926  [0x7fffa5b103db]
    +       2798 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]  (in AppKit) + 2796  [0x7fffa62977ee]
    +         2798 _DPSNextEvent  (in AppKit) + 1120  [0x7fffa5b1ba54]
    +           2798 _BlockUntilNextEventMatchingListInModeWithFilter  (in HIToolbox) + 71  [0x7fffa7582b26]
    +             2798 ReceiveNextEventCommon  (in HIToolbox) + 432  [0x7fffa7582cf1]
    +               2798 RunCurrentEventLoopInMode  (in HIToolbox) + 240  [0x7fffa7582ebc]
    +                 2798 CFRunLoopRunSpecific  (in CoreFoundation) + 420  [0x7fffa8022544]
    +                   2798 __CFRunLoopRun  (in CoreFoundation) + 2221  [0x7fffa802304d]
    +                     2798 __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__  (in CoreFoundation) + 9  [0x7fffa8061d69]
    +                       2798 _dispatch_main_queue_callback_4CF  (in libdispatch.dylib) + 505  [0x7fffbdba7908]
    +                         2798 _dispatch_source_invoke  (in libdispatch.dylib) + 1248  [0x7fffbdb9d13b]
    +                           2798 _dispatch_source_latch_and_call  (in libdispatch.dylib) + 194  [0x7fffbdba5a6c]
    +                             2798 _dispatch_continuation_pop  (in libdispatch.dylib) + 533  [0x7fffbdbafa16]
    +                               2798 _dispatch_client_callout  (in libdispatch.dylib) + 8  [0x7fffbdb9a8fc]
    +                                 2798 TimerActionDevSettings(void*)  (in TotalmixFX) + 162  [0x10001030a]
    +                                   2798 CDevSettings::ProcessRemoteControls()  (in TotalmixFX) + 612  [0x100013e74]
    +                                     2798 CArcp::CheckCyclicArcp(int)  (in TotalmixFX) + 261  [0x10003b463]
    +                                       2798 CArcp::FindAllArcp(signed char)  (in TotalmixFX) + 179  [0x10003b11d]
    +                                         2798 MIDIObjectGetStringProperty  (in CoreMIDI) + 303  [0x10019898b]
    +                                           2798 MIDIClient_ObjectGetStringProperty  (in CoreMIDI) + 243  [0x100176aaa]
    +                                             2798 mach_msg  (in libsystem_kernel.dylib) + 55  [0x7fffbdcf6797]
    +                                               2798 mach_msg_trap  (in libsystem_kernel.dylib) + 10  [0x7fffbdcf734a]
    2798 Thread_77618
    + 2798 thread_start  (in libsystem_pthread.dylib) + 13  [0x7fffbdde908d]
    +   2798 _pthread_start  (in libsystem_pthread.dylib) + 286  [0x7fffbdde9887]
    +     2798 _pthread_body  (in libsystem_pthread.dylib) + 180  [0x7fffbdde993b]
    +       2798 CAPThread::Entry(CAPThread*)  (in CoreMIDI) + 85  [0x1001a8053]
    +         2798 XThread::RunHelper(void*)  (in CoreMIDI) + 10  [0x1001a4a9a]
    +           2798 MIDIProcess::RunMIDIInThread()  (in CoreMIDI) + 105  [0x100197ba9]
    +             2798 XServerMachPort::ReceiveMessage(int&, void*, int&)  (in CoreMIDI) + 107  [0x1001819c1]
    2798 Thread_79498: com.apple.NSEventThread
    +       2798 _NSEventThread  (in AppKit) + 205  [0x7fffa5c68f02]
    +           2798 __CFRunLoopRun  (in CoreFoundation) + 1361  [0x7fffa8022cf1]
    +             2798 __CFRunLoopServiceMachPort  (in CoreFoundation) + 212  [0x7fffa8023874]
    2798 Thread_83381
      2798 start_wqthread  (in libsystem_pthread.dylib) + 13  [0x7fffbdde907d]
        2798 _pthread_wqthread  (in libsystem_pthread.dylib) + 1023  [0x7fffbdde948e]
          2798 __workq_kernreturn  (in libsystem_kernel.dylib) + 10  [0x7fffbdcff44e]
Total number in stack (recursive counted multiple, when >=5):
Sort by top of stack, same collapsed (when >= 5):
        mach_msg_trap  (in libsystem_kernel.dylib)        8394
        __workq_kernreturn  (in libsystem_kernel.dylib)        2798
Binary Images:
       0x100000000 -        0x1000cffff +de.rme-audio.TotalmixFX (1.42 MAC OS X - 1) <FBF61DD9-DE49-30DB-BC69-D3944F3B1B9E> /Applications/Totalmix.app/Contents/MacOS/TotalmixFX
       0x100174000 -        0x1001b2ff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
       0x1001da000 -        0x1001f3ffb  libexpat.1.dylib (15) <F48F1B7B-BEB4-32EE-8C5D-0370096F3864> /usr/lib/libexpat.1.dylib
       0x100242000 -        0x100243ffb  libCyrillicConverter.dylib (69) <9797394A-56E2-393D-B265-F1CF09553FFF> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
       0x1007d4000 -        0x1007d8fff  com.apple.audio.AppleHDAHALPlugIn (279.48 - 279.48) <ECA84145-2AC4-347D-BBC0-933AAAC15356> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
       0x104500000 -        0x1045baff3  com.apple.AMDRadeonX3000GLDriver (1.51.8 - 1.5.1) <E1807F48-B88B-3F85-A825-14729DC097B2> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/AMDRadeonX3000GLDriver
       0x106263000 -        0x106469fff  ATIRadeonX3000SCLib.dylib (1.51.8.1) <7F766CFA-1600-3594-861A-1B394D0736B4> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000SCLib.dylib
       0x10da72000 -        0x10daafdc7  dyld (0.0 - ???) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
    0x7fffa4998000 -     0x7fffa4998fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <D6A08A72-7758-3CA8-813D-105F6E313E67> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fffa4999000 -     0x7fffa49b0ff3  libCGInterfaces.dylib (331.5) <02E9DD16-C5CB-3482-84EF-AA6188A0D28C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fffa49b1000 -     0x7fffa4ff1fe3  com.apple.vImage (8.1 - ???) <4C535C25-EF87-35BE-9BE8-D080A5C24084> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fffa4ff2000 -     0x7fffa51b9fef  libBLAS.dylib (1185.50.4) <7AF8DB9A-E33B-30EB-8767-87AFB951E231> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fffa51ba000 -     0x7fffa51d1fff  libBNNS.dylib (15) <26F32264-148E-35E5-A280-CA035CB3D6F0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fffa51d2000 -     0x7fffa55ddfff  libLAPACK.dylib (1185.50.4) <51B2BABA-F736-3663-885A-65A8991D3560> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fffa55de000 -     0x7fffa55f4fff  libLinearAlgebra.dylib (1185.50.4) <0EC25E70-05DC-3615-85B6-81721566CF1D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fffa55f5000 -     0x7fffa55fbfff  libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fffa55fc000 -     0x7fffa560fff7  libSparseBLAS.dylib (1185.50.4) <0BDCF6A7-0228-3719-81C7-B6EBC7911320> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fffa5610000 -     0x7fffa575dff7  libvDSP.dylib (600.60.1) <F46DF4CB-864D-3541-9913-60521FCBBF4A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fffa575e000 -     0x7fffa5815fe3  libvMisc.dylib (600.60.1) <3A00FDEB-9FAB-3F10-BCB3-316A6BE3C83A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fffa5816000 -     0x7fffa5816fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A2FC8240-F62F-3A23-AB10-8CE6B56AF476> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fffa5ad5000 -     0x7fffa68aeff3  com.apple.AppKit (6.9 - 1504.83.101) <EC7BD195-F9E1-3E43-820A-5FDD0B2B0B67> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fffa68c0000 -     0x7fffa68c0fff  com.apple.ApplicationServices (48 - 48) <4C71CBA8-47E4-38BF-BE3B-F20DF8667D5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fffa68c1000 -     0x7fffa692fff7  com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fffa69c9000 -     0x7fffa6af8ff7  libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fffa6af9000 -     0x7fffa6b43fff  libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fffa6ba0000 -     0x7fffa6bd3fff  libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fffa6c40000 -     0x7fffa6ceaff7  com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fffa6ceb000 -     0x7fffa6d3cfff  com.apple.HIServices (1.22 - 592.1) <7353E76E-9A3A-3693-87AF-41953585E024> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fffa6d3d000 -     0x7fffa6d4cff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fffa6d4d000 -     0x7fffa6d9afff  com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fffa6d9b000 -     0x7fffa6dd6fff  com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fffa6dd7000 -     0x7fffa6de2fff  com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fffa6de3000 -     0x7fffa6feffff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <91D2BA22-B168-3A9A-9008-6FFC5A8FDC1E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fffa6ff0000 -     0x7fffa6ff0fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <8C0153FD-FEFF-309C-AACD-BF9657A31F8E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fffa7159000 -     0x7fffa7533fff  com.apple.CFNetwork (811.5.4 - 811.5.4) <4DBF8932-6286-3B23-87D9-63615B9958D9> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fffa7552000 -     0x7fffa785bfff  com.apple.HIToolbox (2.1.1 - 857.8) <CAB143FE-AEAF-3EDE-AD7B-C04E1B7C5615> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fffa7866000 -     0x7fffa78fdff3  com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fffa791e000 -     0x7fffa7924ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fffa7a05000 -     0x7fffa7a05fff  com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fffa7b4f000 -     0x7fffa7bdcfff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fffa7bdd000 -     0x7fffa7bf0fff  com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fffa7bf1000 -     0x7fffa7ef0ff3  com.apple.CoreData (120 - 754.2) <0C9D9D78-758D-318F-9049-D42CC7944363> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fffa7ef1000 -     0x7fffa7f9dff7  com.apple.CoreDisplay (1.0 - 1) <AAD5DF0B-0D22-305E-86FF-BB1431130363> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fffa7f9e000 -     0x7fffa8431fff  com.apple.CoreFoundation (6.9 - 1349.8) <36385A3A-60D3-32DB-BF55-C6D8931A7AA6> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fffa8432000 -     0x7fffa8ad5ff7  com.apple.CoreGraphics (2.0 - 1070.22) <C84DAB96-313D-392C-817E-B8F816AF52E9> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fffa8ad6000 -     0x7fffa8d19ffb  com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fffa8e7e000 -     0x7fffa8e7efff  com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fffa8e7f000 -     0x7fffa8ed0fff  com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fffa8ed1000 -     0x7fffa91acff7  com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fffa91ad000 -     0x7fffa91e0fff  com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fffa91e1000 -     0x7fffa91e9ff3  com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fffa91ea000 -     0x7fffa9356ff7  com.apple.LaunchServices (775.19 - 775.19) <94D15A2A-852C-3B4B-A701-43043C8F1527> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fffa9357000 -     0x7fffa9407ffb  com.apple.Metadata (10.7.0 - 1075.40) <DA911E1B-3977-386D-930D-96BD5085CB8E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fffa9408000 -     0x7fffa9467fff  com.apple.CoreServices.OSServices (775.19 - 775.19) <C709A773-4FA0-33DD-B3E2-FBA41E00F177> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fffa9468000 -     0x7fffa94d8fff  com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fffa94d9000 -     0x7fffa951eff7  com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fffa95a7000 -     0x7fffa96f4ffb  com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fffa96f5000 -     0x7fffa972aff3  com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fffa972b000 -     0x7fffa979cffb  com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fffa989a000 -     0x7fffa989ffff  com.apple.DiskArbitration (2.7 - 2.7) <8AC72143-D3C4-3AA6-84DF-734E3AFAC49B> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fffa9a31000 -     0x7fffa9dd7ff3  com.apple.Foundation (6.9 - 1349.81) <730B7944-BB43-35D5-A546-9F6CCED4B9F3> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fffa9e03000 -     0x7fffa9e34ff7  com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fffa9ef4000 -     0x7fffa9f97ffb  com.apple.Bluetooth (5.0.4 - 5.0.4f18) <B3FED7E7-45EE-32DD-B59E-7942BCE9426C> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fffa9f98000 -     0x7fffaa02eff7  com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fffaa02f000 -     0x7fffaa035ffb  com.apple.IOSurface (159.7 - 159.7) <40550017-EF96-3C52-B400-806AFEE4B134> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fffaa088000 -     0x7fffaa1ebff7  com.apple.ImageIO.framework (3.3.0 - 1599.10.2) <2C7959FF-6EFB-3D43-BFD2-4A3F79F71744> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fffaa1ec000 -     0x7fffaa1f0fff  libGIF.dylib (1599.10.2) <90A3031D-BAB3-3AFF-9FAE-BA7B9632D63C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fffaa1f1000 -     0x7fffaa2e2ff7  libJP2.dylib (1599.10.2) <2090C3B2-6D5F-3700-A327-B9477864391D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fffaa2e3000 -     0x7fffaa306fff  libJPEG.dylib (1599.10.2) <6802719D-5E3B-3C39-82CC-7D38C28050FB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fffaa307000 -     0x7fffaa32dfff  libPng.dylib (1599.10.2) <5DD80388-D65D-31DC-9344-DB0C2B5582B6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fffaa32e000 -     0x7fffaa330ff3  libRadiance.dylib (1599.10.2) <CD0C366B-C2EA-3A4A-AF7F-74107AB84D8D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fffaa331000 -     0x7fffaa37fffb  libTIFF.dylib (1599.10.2) <B6F55587-78B1-3A09-8126-661AFC6CEA02> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fffab0e6000 -     0x7fffab0ffff7  com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fffab8de000 -     0x7fffab939fff  com.apple.Metal (87.18 - 87.18) <5C2F12FB-45C1-3103-A827-3D225BF8D05A> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fffac222000 -     0x7fffac22afff  com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fffac401000 -     0x7fffac409ff7  libcldcpuengine.dylib (2.8.5) <73E1E526-01DF-3199-9B48-155F0329EF44> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fffac5d2000 -     0x7fffac620ff3  com.apple.opencl (2.8.6 - 2.8.6) <5FAF6F49-2648-39E6-922B-5630A5D7F7E4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fffac621000 -     0x7fffac63affb  com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fffac63b000 -     0x7fffac646ff7  com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fffac647000 -     0x7fffac649fff  libCVMSPluginSupport.dylib (14.0.16) <A20EC348-37C9-33B6-9A81-06006F3214A1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fffac64a000 -     0x7fffac64dff7  libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fffac64e000 -     0x7fffac652fff  libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fffac653000 -     0x7fffac65cff7  libGFXShared.dylib (14.0.16) <63542E68-EB1A-3ECF-AAFB-E7B8AB313C70> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fffac65d000 -     0x7fffac668fff  libGL.dylib (14.0.16) <84BEED97-0A93-356D-A922-97EA311EA446> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fffac669000 -     0x7fffac6a5ff7  libGLImage.dylib (14.0.16) <3518A85C-6905-3511-A6C9-2F82C519D28F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fffac6a6000 -     0x7fffac81cff3  libGLProgrammability.dylib (14.0.16) <0EDA89D8-7C28-3D53-BDBA-7CB25232C329> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fffac81d000 -     0x7fffac85eff7  libGLU.dylib (14.0.16) <9860DCF7-56E0-3A8F-A377-52635C9D8B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fffad1c6000 -     0x7fffad1d4fff  com.apple.opengl (14.0.16 - 14.0.16) <27E7D76E-A26B-39F8-8CF2-AB57920776A3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fffad1d5000 -     0x7fffad37bfff  GLEngine (14.0.16) <1999FBF9-0B82-34B1-8876-87B4F82101BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fffad37c000 -     0x7fffad3a6fff  GLRendererFloat (14.0.16) <8D11C08E-8249-38DB-9856-BFC01EEDE0CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fffadef8000 -     0x7fffae0f8fff  com.apple.QuartzCore (1.11 - 453.39.3) <AB46D60D-17A8-3122-800E-2A9DA604FCBA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fffae65f000 -     0x7fffae961ff7  com.apple.security (7.0 - 57740.60.18) <021AACF6-D15F-37E0-840B-88853684BA00> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fffae962000 -     0x7fffae9d7fff  com.apple.securityfoundation (6.0 - 55132.50.7) <4433C0CC-FE90-3DD3-BAC1-CC31D515B510> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fffaea02000 -     0x7fffaea05ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <9F285B19-B53B-3502-85A2-72C26DB40EA7> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fffaed8c000 -     0x7fffaedfbff7  com.apple.SystemConfiguration (1.14 - 1.14) <2412CDE0-C317-31EA-8F53-7A58BBFCC720> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fffb167a000 -     0x7fffb169cffb  com.apple.framework.Apple80211 (12.0 - 1200.47) <B692048E-1B61-3DAF-9CBA-4D314E7562DC> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fffb169d000 -     0x7fffb16acfeb  com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fffb1795000 -     0x7fffb182097f  com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fffb1c53000 -     0x7fffb1cd1ff7  com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fffb295c000 -     0x7fffb2983ff3  com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fffb32a8000 -     0x7fffb32b1ffb  com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fffb39f9000 -     0x7fffb3a09fff  com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fffb3d44000 -     0x7fffb3d74ff3  com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fffb4005000 -     0x7fffb4094ff7  com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fffb4095000 -     0x7fffb41d4fe7  com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fffb41d5000 -     0x7fffb42a5ff3  com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fffb42f5000 -     0x7fffb435aff3  com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fffb435b000 -     0x7fffb4369ff7  com.apple.CrashReporterSupport (10.12 - 827) <14037A71-ECFE-394A-8D6E-2CECE98F02EE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fffb43db000 -     0x7fffb43e5ffb  com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fffb43e6000 -     0x7fffb43eaff3  com.apple.DSExternalDisplay (3.1 - 380) <A195C0CE-8E4E-384B-9556-8270E306FE1D> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fffb4420000 -     0x7fffb4495ffb  com.apple.datadetectorscore (7.0 - 539.1) <9C312AAC-8AEE-3C72-BDE5-7FBF62452525> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fffb44d1000 -     0x7fffb4510fff  com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fffb4511000 -     0x7fffb4622fff  com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fffb490a000 -     0x7fffb4d3bff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fffb6092000 -     0x7fffb6092fff  libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fffb609f000 -     0x7fffb60aaff3  libGPUSupportMercury.dylib (14.0.16) <7E99C736-2F48-313E-BEF6-6F8BABFADD9F> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fffb6363000 -     0x7fffb637ffff  com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fffb6a90000 -     0x7fffb6b06ff3  com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fffb7121000 -     0x7fffb7128ffb  com.apple.IOAccelerator (311.13 - 311.13) <40C04C41-A76A-3687-8D64-F76E8C46AA81> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fffb712a000 -     0x7fffb713eff7  com.apple.IOPresentment (1.0 - 29.10) <A3F7C1F6-CE50-3804-AAAF-7B75EBC46BE4> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fffb713f000 -     0x7fffb7161fff  com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fffb7248000 -     0x7fffb73fffff  com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fffb7d20000 -     0x7fffb7d99ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fffb7f13000 -     0x7fffb7f3bff7  com.apple.MultitouchSupport.framework (368.16 - 368.16) <512ADEC6-D694-3D73-A48A-6BE79CD39539> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fffb7fed000 -     0x7fffb7ff8fff  com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fffb88d0000 -     0x7fffb8911ff3  com.apple.PerformanceAnalysis (1.148.3 - 148.3) <6A21AB41-3AAA-32F3-9D46-2555A143A8B9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fffb8ff9000 -     0x7fffb9013fff  com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fffb902c000 -     0x7fffb904fff3  com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fffb9da8000 -     0x7fffb9e35fff  com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fffb9e56000 -     0x7fffba0cbff3  com.apple.SkyLight (1.600.0 - 170.3) <F373A7DA-B687-35AF-90E3-178945A5DAD1> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fffba2aa000 -     0x7fffba2b6ff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fffba9a2000 -     0x7fffbaa16fdf  com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fffbae55000 -     0x7fffbae5bff7  com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fffbaee7000 -     0x7fffbafadff7  com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fffbb021000 -     0x7fffbb022fff  com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fffbb023000 -     0x7fffbb1b3ff3  com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fffbc264000 -     0x7fffbc266ffb  com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fffbc2bb000 -     0x7fffbc2d6ff7  libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
    0x7fffbc2d7000 -     0x7fffbc2e2fff  libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
    0x7fffbc374000 -     0x7fffbc375ff3  libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fffbc376000 -     0x7fffbc589fff  libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
    0x7fffbc5ad000 -     0x7fffbc5adfff  libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
    0x7fffbc5ae000 -     0x7fffbc5b2ffb  libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
    0x7fffbc5b3000 -     0x7fffbc5b4ffb  libSystem.B.dylib (1238.60.2) <FC9E9F13-3B18-305C-BE0A-97C7843652B0> /usr/lib/libSystem.B.dylib
    0x7fffbc620000 -     0x7fffbc64bff3  libarchive.2.dylib (41.50.2) <B4F507BC-B24E-3BE7-B658-94D798E2CD81> /usr/lib/libarchive.2.dylib
    0x7fffbc64c000 -     0x7fffbc741fef  libate.dylib (1.12.13) <DB9881C3-E24A-3984-91E0-77F6F13F795C> /usr/lib/libate.dylib
    0x7fffbc745000 -     0x7fffbc745ff3  libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
    0x7fffbc746000 -     0x7fffbc756ff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
    0x7fffbc757000 -     0x7fffbc765ff7  libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
    0x7fffbc766000 -     0x7fffbc7bcff7  libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
    0x7fffbc7bd000 -     0x7fffbc7e7fff  libc++abi.dylib (307.3) <30199352-88BF-30BD-8CFF-2A4FBE247523> /usr/lib/libc++abi.dylib
    0x7fffbc7e8000 -     0x7fffbc7f8ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
    0x7fffbc7f9000 -     0x7fffbc80fff7  libcompression.dylib (39) <BDAA8CC7-0BFC-36EC-9E75-58BDC15AC3B6> /usr/lib/libcompression.dylib
    0x7fffbc810000 -     0x7fffbc810ff7  libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
    0x7fffbc811000 -     0x7fffbc812ff3  libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fffbc8cc000 -     0x7fffbc9b1ff7  libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
    0x7fffbcb4f000 -     0x7fffbcba2ff7  libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
    0x7fffbcc1d000 -     0x7fffbcc1dfff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
    0x7fffbcc2d000 -     0x7fffbcc32ff7  libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
    0x7fffbcc33000 -     0x7fffbcd25ff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
    0x7fffbcd26000 -     0x7fffbcf4bffb  libicucore.A.dylib (57165.0.1) <2931B842-2946-3576-AD1D-1CDA22FA1388> /usr/lib/libicucore.A.dylib
    0x7fffbcf51000 -     0x7fffbcf52fff  liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
    0x7fffbcf53000 -     0x7fffbcf6cffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
    0x7fffbcf6d000 -     0x7fffbcf83ff7  libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
    0x7fffbcf84000 -     0x7fffbd22cff7  libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
    0x7fffbd25f000 -     0x7fffbd2d9ff3  libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
    0x7fffbd2da000 -     0x7fffbd6afbc7  libobjc.A.dylib (709) <54CD8D1A-5C98-3559-B13A-932B3D3DD338> /usr/lib/libobjc.A.dylib
    0x7fffbd6b2000 -     0x7fffbd6b6fff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
    0x7fffbd6b7000 -     0x7fffbd6e8fff  libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
    0x7fffbd705000 -     0x7fffbd721ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
    0x7fffbd771000 -     0x7fffbd8b7fff  libsqlite3.dylib (254.7) <65EA6A12-DAB8-3727-96DB-16918EBCC247> /usr/lib/libsqlite3.dylib
    0x7fffbd913000 -     0x7fffbd963fff  libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
    0x7fffbd9ac000 -     0x7fffbd9b9fff  libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
    0x7fffbd9ba000 -     0x7fffbdaa9ffb  libxml2.2.dylib (30.16) <D2A6861B-D9FA-3BFC-B664-830C3FCE6065> /usr/lib/libxml2.2.dylib
    0x7fffbdaaa000 -     0x7fffbdad3fff  libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
    0x7fffbdad4000 -     0x7fffbdae5ff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
    0x7fffbdaf4000 -     0x7fffbdaf8ff7  libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
    0x7fffbdaf9000 -     0x7fffbdb03fff  libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
    0x7fffbdb04000 -     0x7fffbdb0bfff  libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
    0x7fffbdb0c000 -     0x7fffbdb14fff  libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
    0x7fffbdb15000 -     0x7fffbdb98fdf  libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
    0x7fffbdb99000 -     0x7fffbdbcafff  libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
    0x7fffbdbcb000 -     0x7fffbdbd0ffb  libdyld.dylib (433.5) <EC3D88D2-3D40-3274-8E26-362C2D7352C8> /usr/lib/system/libdyld.dylib
    0x7fffbdbd1000 -     0x7fffbdbd1ffb  libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
    0x7fffbdbd2000 -     0x7fffbdbdeffb  libkxld.dylib (3789.60.24) <5DFCDC05-6CBC-35A6-8B92-DF6803492E12> /usr/lib/system/libkxld.dylib
    0x7fffbdbdf000 -     0x7fffbdbdffff  liblaunch.dylib (972.60.2) <D3306CFF-58AA-3C90-B06C-B70E80E60C5B> /usr/lib/system/liblaunch.dylib
    0x7fffbdbe0000 -     0x7fffbdbe5ff3  libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
    0x7fffbdbe6000 -     0x7fffbdbe8ff3  libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
    0x7fffbdbe9000 -     0x7fffbdbeaffb  libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
    0x7fffbdbeb000 -     0x7fffbdc03ff7  libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
    0x7fffbdc04000 -     0x7fffbdc04ff7  libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
    0x7fffbdc05000 -     0x7fffbdc92fef  libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
    0x7fffbdc93000 -     0x7fffbdc96ffb  libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
    0x7fffbdc97000 -     0x7fffbdc9afff  libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
    0x7fffbdc9b000 -     0x7fffbdcb3fff  libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
    0x7fffbdcb4000 -     0x7fffbdcbafff  libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
    0x7fffbdcbb000 -     0x7fffbdce4ff7  libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
    0x7fffbdce5000 -     0x7fffbdd07ff7  libsystem_kernel.dylib (3789.60.24) <6E9E485F-91F6-36B7-A125-AE91DC978BCC> /usr/lib/system/libsystem_kernel.dylib
    0x7fffbdd08000 -     0x7fffbdd4ffe7  libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
    0x7fffbdd50000 -     0x7fffbdd6eff7  libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
    0x7fffbdd6f000 -     0x7fffbddc8ffb  libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
    0x7fffbddc9000 -     0x7fffbddd2ff3  libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
    0x7fffbddd3000 -     0x7fffbdddcff3  libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
    0x7fffbdddd000 -     0x7fffbdde5fe7  libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
    0x7fffbdde6000 -     0x7fffbddf0ff7  libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
    0x7fffbddf1000 -     0x7fffbddf4ff7  libsystem_sandbox.dylib (592.60.1) <DC780631-BD23-36B1-9376-668619E18D25> /usr/lib/system/libsystem_sandbox.dylib
    0x7fffbddf5000 -     0x7fffbddf6ff3  libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
    0x7fffbddf7000 -     0x7fffbddfeffb  libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
    0x7fffbddff000 -     0x7fffbde12ff7  libsystem_trace.dylib (518.60.2) <6B145B10-5874-3E89-90CD-D370DB475BA1> /usr/lib/system/libsystem_trace.dylib
    0x7fffbde13000 -     0x7fffbde18ffb  libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
    0x7fffbde19000 -     0x7fffbde42ff7  libxpc.dylib (972.60.2) <1C9AF716-69DF-359F-85E9-7DFDE362F9A2> /usr/lib/system/libxpc.dylib
Sample analysis of process 715 written to file /dev/stdout
12 (edited by dpoul 2017-06-12 08:14:19)
One thing that work!!!
I go to HD/Library/Audio/MIDI Driver/ and delete MADIfaceUSB3MlDlDriver.plugin from there (put it to desktop to insure) and reboot my Mac, and after that all work but how long it will work I don't know, after all that Totalmix Fx loaded perfectly.
I think it was something like conflict maybe between midi of my keyboard and midi function of Babyface Pro, maybe they loaded at same time .
13
Thanks for the log. It shows that there is a hanging MIDI server that makes TM FX hang while looking for MIDI ports. Removing MADIfaceUSB3MlDlDriver.plugin doesn't help as it is not even active for your Babyface Pro, it was the reboot that fixed it - for now.
Can you please open Audio MIDI Setup, Show MIDI Studio, and tell us what you find in there? Or post a screenshot. Most probably you installed one or more MIDI drivers/plugins, and one of these might cause the hang.
Also do you have any other MIDI devices connected to your computer?
Link to Screenshot MIDI Studio.
I only have Keyboard connected Thru MIDI Mate 2.
15
Thanks. We will provide a test version soon, please stay tuned.
TotalMix FX 1.43 b2 includes a workaround which might help. Please try it:
https://www.forum.rme-audio.de/viewtopi … 44#p122244
I'm tried it already, and it's work well for now, but what will be after a system re-install, I don't know so far.
18
Did you put the MADIfaceUSB3MlDlDriver.plugin back?
no
20
Please do so.
21 (edited by dpoul 2017-06-16 22:01:34)
now I'm back this file to place where I taking it, and it work, but total mix anyway got some delay( 5 - 10 seconds) between click(jumping in tray) and appearing on screen.
Some time earlier(before I open thread on this forum), it opens right after click immediately.
