Topic: Encoder 1 and 2 don't alter bass/treble anymore?
It used to be the case that when I had (for example) Phones Out 3/4 displayed and I turned encoder 1 and 2 it altered the bass / treble - but now when I do this nothing happens. Pressing them still cycles through the screens (State Overview, etc...).
Is this something I've done or is it a change due to firmware?
Any ideas how I can get the former functionality back?
Thank you.
Re: Encoder 1 and 2 don't alter bass/treble anymore?
Typically you either play back DSD, or the sample rate is higher than 192 kHz. But you could also check that the Bass/Treble On/Off entry is not set to OFF in the Bass/Treble menu of outputs 3/4.
Thanks MC! Yes it was that the sample rate was too high. I'm not sure how it went back to being so high, but now it's back to what it should be smile
I wonder ... would it be a good idea for a message to appear "Sample rate too high" when the knobs are twiddled if the sample rate is too high?
