Topic: RME + Ableton Issue
Hi all,
For some reason I get this very weird problem. When I have certain Ableton projects running which are not super heavy (20/30% on the CPU meter) The totalmix behaves super sluggish: I have the UFX with arc and it doesn't respond well to the volume wheel/buttons. It also goes out of sync: the sound starts distorting as if I put a bit crusher on it.
When this happens its not only Ableton which doesn't work properly: When I play a sound in the finder the same stuff happens.
When I use Cubase (also most recent version) All is fine, even when I push it.
I can work around this to give the UFX a different buffer rate in Ableton, or restart the UFX. But its very annoying as this takes time and can kill the workflow. It seems to happen randomly.
- Drivers for Totalmix/hardware RME: driver 3.03 / hardware: v357. I will install the v359 to see if there are differences.
- Most recent Ableton (9.7.4)
- Most recent Sierra version (10.12.6)
