Topic: PCI vs PCIe , Differences? Latency?
Hello! Im planning to build a Micro ATX PC for live gigs. I want to get the best portable solution (cause I already have many gear to carry...) I play E Drums with a bunch of MIDI controllers using Drum racks and FX in Ableton Live.
So I´ve been researching and I want a PCI RME interface because of its stability and low latency.
It is not really and affordable solution cause at least I need 16 outputs and PCIe interfaces are not that cheap and moreover , you have to expand with MADI , AES or ADAT.
I was thinking on getting a Hammerfall HDSP 9652 And a pair of AEB8-O , and that would give me 16 outputs directly from the CPU to the mixer.
Problem is that nowadays , almost no motherboard (and specially no micro or mini ATX) come with PCI Slots anymore , but I´ve found this Gigabyte motherboard , which I would use with a 7700K Processor :
http://www.game-debate.com/motherboard/ … ev.%201.0)
The other possible solution would be to get a new Ryadat with a pair of ADAT systems , but I´m concerned about the added latency.
But the biggest and main question is : Is there such a difference (specially talking about latency , stability and performance) between the RME PCI and PCIe cards?...
And also , I think that if the latency trip happens inside the PC (HDSP With AEB8-O) it would be lower than the HDSPe Ryadat to ADAT system? I´m not sure about this... could some one explain this?
Thanks! and take care!
