Topic: Babyface and High Sierra
I bought a new imac 2017 and put the new TotalMix FX driver_usb_mac_303.zip.
TotalMix FX does not work, the mixer window does not opening, there is no device in the Device Selection.
Decided to flash the device itself fut_usb_mac.zip, it is also not flashed.
Tried to do it on other laptops, the situation there is the same.
On Windows 7 everything works fine. What can be done in this case?
https://ibb.co/cif8V6
Re: Babyface and High Sierra
https://ibb.co/eHkWiR
3
https://www.forum.rme-audio.de/viewtopic.php?id=26077
I did all this steps.
MartinG wrote:
Great That worked!!
here's  how:
1. System preferences:  security and settings - allow apps from apple & identified
2. install RME Driver 3.03
3. Restart
4. System preferences (Again) :  Click on the new button, which allow RME driver to be installed
Done
nothing changed!
and 2 question why I couldn't flash my device?
5
The BF might be in Class Compliant mode. But then it wouldn't work under Windows 7.
So you clicked the button that allowed the RME driver? Then rebooted the Mac?
What happens when you click on the 'Update' button in the Flash tool?
I sloved the problem with Totalmix fx, reinstated in 2nd time. Thanks!
when I click on button Update - nothing changed.
flash updater on windows 7 can not flash on 225 firmware, the latest update on windows is 223.
on Mac pushing this button begin blue for a second and nothing happened.
https://ibb.co/bEjVcm
8
I just did that with the current FUT from our download pages (file date 28 September). Worked as expected.
