1. Push knob "i/o"
2. push encoder 1 several times to ensure you are not in a submenu
when you reaced the top, then you see
- in the 1st line rightmost the (1) which represents "output channel to be changed by turning encoder 1"
- in the 2nd line rightmost the (2) which represents "function to be changed by turning encoder 2"
3. turn encoder 1 to sweep through the channels, stop when you see "Main Output 1/2" in the 1st line of display
4. turn encoder 2 to sweep through the functions for "Main Output 1/2", stop when you see "Loudness" in the 2nd line of display
5. push encoder 2/1 to go through the settings of "Loudness" for output channel 1/2.
6. turn encoder 2 to change the values of a configuration item in the Loudness menue
There is a diagram in the handbook how the menue is organized.
