I am not sure whether you are aware of this possibility to use both interfaces
and to expand your UCX by i.e. 8 additional line IN and OUT channels via ADAT.
For this
- keep both drivers installed
- connect UCX and Multiface to your PC
- connect UCX and Multiface by 2 ADAT cables (UCX ADAT OUT to MF ADAT IN and vice versa)
Clock settings in the RME driver settings dialog:
- UCX: set clock source to "internal" (Master)
- Multiface: set clock source to "ADAT" (Slave)
If you cabled correctly then you should see in the RME driver settings dialog the ADAT status changing to "sync".
Then the Multiface is clock synchronized to the UCX.
If only 1 TotalMix FX window opened, then you can either work with this one window and change between both devices by clicking to the upper right where the device name is shown. Pop-Up window openes where you can select, which device you want to maintain ...
Alternatively you can open a new TotalMix window, select the 2nd device, arrange the 2 TM windows on your screen, so that you can configure them both.
For the Multiface you could then route i.e.
- the 8 analog inputs to ADAT 1..8, so that they become available for the UCX as ADAT1..8 IN ...
- the 8 ADAT inputs to analog 1..8 out, so that they become available for the UCX as ADAT1..8 OUT ...
Save this i.e. in Snapshot1 of the TotalMix Instance for the Multiface and rename it i.e. "Lines4UCX".
The Multiface works now in kind of "standalone" operation modus and has a fixed routing which expands your UCX by having 8 more analog inputs and outputs.
What you should do now
- save snapshot and workspace
- assign this new setup to a workspace quick select slot under the name "UCX and Multiface +8 Analog IN and OUT".
I recommend the following TM FX Preferences (F2)
- Snapshots -> ( ) Do not load Main volume/balance
- Devuce Handling -> (X) Always init DSP devices with TotalMix FX settings
By this you always initialize both devices with the configuration saved on your PC.
Especially the volume has then always defined values as saved in your snapshots not to blow your ears.
Voila, a nice solution to you ...
In the DAW you only work with the ASIO driver of the UCX.
The ADAT1..8 IN and OUT channels make now available the Analog 1..8 ports of your Multiface.
If you say that you need ADAT on the UCX for a Preamp .... then you can do
But as preamps only rarely support 2 or more additional analog outputs (with a few exceptions)
then you can still use the Multiface to provide 8 additional analog outputs.
But then you require Wordclock cabling between the three devices,
as your Preamp only can get clock by an incoming ADAT signal....
