Topic: Complete newbie. How do I get started and what's possible?
Hi!
I've been using the RME UFX on firewire for years via firewire on an old 2006k. Recently I notice crackling and popping. I think it's the old machine not able to deal with plugins but it's even happening on mixdown at the highest buffer rate. This actually coincided when I upgraded to Cubase 9.5. I'm using Windows 10 professional.
Also, I miss the not worrying about latency that comes with PCIe, at home, and don't know what I need to use my RME UFX as an interface and what card I would need. I also plan to finally upgrade my computer to an i9 so that may take care of my problems.
At any rate, if I were to use my RME UFX as an interface is the RME HDSPe RayDAT the only card I would use? Does it come with appropriate cables or do I need to buy them separately? Where do I plug them in? The optical and midi ports or would I now connect my two MIDI directly into the card?
Does totalmix still have the same options my USB/Firewire interface has?
Any help, guide, advice where to buy and what to buy will be greatly appreciated! In the many years I've had my RME/UFX I've never had to post here so just signed up today. I absolutely love it. It's a fantastic machine except my computer is now old and, I'm told, USB 2.0 is no longer relevant. Thank you for any help.
Re: Complete newbie. How do I get started and what's possible?
Perhaps you mean "converter", not interface. The UFX is a completely independent audio interface, and USB 2.0 is fully sufficient to operate it.
You can, of course, also use it as a standalone converter connected to a Raydat, but if there is a performance issue of your PC, a PCIe card won't necessarily solve that....
I would suggest to try the UFX connected to USB with your new system and see what happens.
Thank you for your time and insight. I will try that before I look further into purchasing the Raydat PCIe card.
Still, if you can provide me a link to a guide as to what i will need and how it can be connected, I would be greatly appreciative.
Best Regards,
John
4 (edited by ramses 2018-03-23 00:08:22)
EDIT1
USB2 is still the standard if a recording interface has less then 64 i/o channels.
Therefore even the new UFX II has still USB2 ports.
The UFX+ requires USB3/Thunderbolt as it has 94 IN / OUT.
If you hear crackles with the UFX even at higher sample rates might indicate that
- either you have more complex projects require bigger CPU or
- that you maybe installed new driver / HW which block your EDIT1: CPU
If you get a more powerful machine I would try the UFX again.
- that you maybe installed new driver / HW which block your machine
Thank you, sir, I will do that. I do think it's related to the lack of power of my old system.
