Topic: My gear is failing the bit test
Hi guys,
I have been enjoying my ADI-2 Pro very much for a few months now and only today have I decided to try the bit test. Much to my surprise, not a single file went through. I am no audio pro at all, just an enthusiast, and I have little to no idea how to troubleshoot this. Would anyone be willing to take a look at my configuration for us to see if I am overlooking something please?
ADI-2 Pro 174/86
MacOS High Sierra 10.13.3
HQPlayer Desktop 3.20.2 (EVALUATION)
Audio MIDI Setup in MacOS and HQPlayer preferences
https://ulozto.sk/tam/_VP6OrYUy62h2 (a file sharing service, two .png images, 340kB both)
HQPlayer log
start player...
* 2018/03/18 21:03:58 Starting...
2018/03/18 21:03:58 Signalyst HQPlayer Desktop v3.20.2
2018/03/18 21:03:58 Engine selected:
* 2018/03/18 21:03:59 Control server started
2018/03/18 21:04:04 Restore GUI state
2018/03/18 21:04:04 libDSP version 19.1.2
2018/03/18 21:04:04 Number of processor cores: 2
2018/03/18 21:04:04 DSP thread pools disabled
2018/03/18 21:04:04 Pipelined DSP disabled
2018/03/18 21:04:04 Audio engine: coreaudio
2018/03/18 21:04:04 Set channels: 2 (2)
2018/03/18 21:04:04 CoreAudio default device id: 48
2018/03/18 21:04:04 CoreAudio devices: 3
2018/03/18 21:04:04 CoreAudio device: Built-in Microphone (41) - Apple Inc.
2018/03/18 21:04:04 CoreAudio device: Built-in Output (48) - Apple Inc.
2018/03/18 21:04:04 CoreAudio device: ADI-2 Pro (56382175) (58) - RME
2018/03/18 21:04:04 CoreAudio selected device: 58
2018/03/18 21:04:04 CoreAudio nominal rate: 44100 - 44100
2018/03/18 21:04:04 CoreAudio nominal rate: 48000 - 48000
2018/03/18 21:04:04 CoreAudio nominal rate: 88200 - 88200
2018/03/18 21:04:04 CoreAudio nominal rate: 96000 - 96000
2018/03/18 21:04:04 CoreAudio nominal rate: 176400 - 176400
2018/03/18 21:04:04 CoreAudio nominal rate: 192000 - 192000
2018/03/18 21:04:04 CoreAudio nominal rate: 352800 - 352800
2018/03/18 21:04:04 CoreAudio nominal rate: 384000 - 384000
2018/03/18 21:04:04 CoreAudio nominal rate: 705600 - 705600
2018/03/18 21:04:04 CoreAudio nominal rate: 768000 - 768000
2018/03/18 21:04:04 CoreAudio number of streams: 2
2018/03/18 21:04:04 CoreAudio number of output streams: 1
2018/03/18 21:04:04 CoreAudio virtual formats:
2018/03/18 21:04:04 768000/32/2 [ Float ]
2018/03/18 21:04:04 705600/32/2 [ Float ]
2018/03/18 21:04:04 384000/32/2 [ Float ]
2018/03/18 21:04:04 352800/32/2 [ Float ]
2018/03/18 21:04:04 192000/32/2 [ Float ]
2018/03/18 21:04:04 176400/32/2 [ Float ]
2018/03/18 21:04:04 96000/32/2 [ Float ]
2018/03/18 21:04:04 88200/32/2 [ Float ]
2018/03/18 21:04:04 48000/32/2 [ Float ]
2018/03/18 21:04:04 44100/32/2 [ Float ]
2018/03/18 21:04:04 768000/32/2 [ SignedInteger NonMixable ]
2018/03/18 21:04:04 705600/32/2 [ SignedInteger NonMixable ]
2018/03/18 21:04:04 384000/32/2 [ SignedInteger NonMixable ]
2018/03/18 21:04:04 352800/32/2 [ SignedInteger NonMixable ]
2018/03/18 21:04:04 192000/32/2 [ SignedInteger NonMixable ]
2018/03/18 21:04:04 176400/32/2 [ SignedInteger NonMixable ]
2018/03/18 21:04:04 96000/32/2 [ SignedInteger NonMixable ]
2018/03/18 21:04:04 88200/32/2 [ SignedInteger NonMixable ]
2018/03/18 21:04:04 48000/32/2 [ SignedInteger NonMixable ]
2018/03/18 21:04:04 44100/32/2 [ SignedInteger NonMixable ]
2018/03/18 21:04:04 CoreAudio physical formats:
2018/03/18 21:04:04 768000/32/2 [ SignedInteger ]
2018/03/18 21:04:04 705600/32/2 [ SignedInteger ]
2018/03/18 21:04:04 384000/32/2 [ SignedInteger ]
2018/03/18 21:04:04 352800/32/2 [ SignedInteger ]
2018/03/18 21:04:04 192000/32/2 [ SignedInteger ]
2018/03/18 21:04:04 176400/32/2 [ SignedInteger ]
2018/03/18 21:04:04 96000/32/2 [ SignedInteger ]
2018/03/18 21:04:04 88200/32/2 [ SignedInteger ]
2018/03/18 21:04:04 48000/32/2 [ SignedInteger ]
2018/03/18 21:04:04 44100/32/2 [ SignedInteger ]
2018/03/18 21:04:04 CoreAudio device bits: 32
2018/03/18 21:04:04 Volume limit: 0
2018/03/18 21:04:04 Automatic rate family disabled
2018/03/18 21:04:04 DirectSDM disabled
2018/03/18 21:04:04 SDM conversion parameters (0, 0)
2018/03/18 21:04:04 DSD 6 dB gain disabled
2018/03/18 21:04:04 Initial parallel threads: 4
2018/03/18 21:04:04 Number of logical cores: 4
2018/03/18 21:04:04 Audio engine PCM mode enabled
& 2018/03/18 21:04:04 Stop...
2018/03/18 21:04:04 Set filter: 6
2018/03/18 21:04:04 Set dither: 5
2018/03/18 21:04:04 Set filter: 0
2018/03/18 21:04:04 Set oversampling: 6
2018/03/18 21:04:04 Automatic output rate switching enabled
2018/03/18 21:04:04 Set dither: 0
2018/03/18 21:04:04 Set modulator: 6
play 192_24_adi2pro_bittest 4s.wav...
& 2018/03/18 21:05:28 Playlist clear
& 2018/03/18 21:05:28 Stop...
& 2018/03/18 21:05:28 Set transport (240):
& 2018/03/18 21:05:28 Playlist add URI: file:///Users/jogobella/Desktop/music/bit_test_wavs/192_24_adi2pro_bittest 4s.wav
2018/03/18 21:05:34 Set convolution: 1
& 2018/03/18 21:05:34 GoTo 1
& 2018/03/18 21:05:34 Play
+ 2018/03/18 21:05:34 Playback engine running
2018/03/18 21:05:34 Set sampling rate: 192000 (192000)
2018/03/18 21:05:34 Rate or blocksize change triggered
2018/03/18 21:05:34 Rate: 192000, block size: 20480, frame size: 2560
2018/03/18 21:05:34 Block size: 20480 (sample: 4)
2018/03/18 21:05:34 Playback engine ratio: 1
2018/03/18 21:05:34 Dither: none for 32-bit
2018/03/18 21:05:34 Initialization complete, starting audio engine
+ 2018/03/18 21:05:34 CoreAudio engine starting...
2018/03/18 21:05:34 CoreAudio using integer mode
2018/03/18 21:05:34 CoreAudio virtual format: 192000/32/2 [ SignedInteger NonMixable ]
2018/03/18 21:05:34 CoreAudio using non-mixable mode
2018/03/18 21:05:34 CoreAudio physical format: 192000/32/2 [ SignedInteger NonMixable ]
+ 2018/03/18 21:05:35 CoreAudio engine started at: 192000 (192000)
2018/03/18 21:05:35 Parallel threads: 4
2018/03/18 21:05:35 Nested parallelism: 0
2018/03/18 21:05:35 Parallel pipelines: 2
2018/03/18 21:05:36 CoreAudio allocate buffers of size 512
2018/03/18 21:05:40 End of track
& 2018/03/18 21:05:40 Next
2018/03/18 21:05:40 Stop request (tail)
& 2018/03/18 21:05:41 Stop...
- 2018/03/18 21:05:41 CoreAudio engine stopping...
- 2018/03/18 21:05:42 CoreAudio engine stopped
- 2018/03/18 21:05:42 Playback engine stopped
& 2018/03/18 21:05:42 ...stopped
