Topic: Two Multiface II and Two PCIe cards (looking for experienced opinion)
Hello guys. Newbie here. I am considering to get two Multiface II interfaces with two individual PCIe cards. Only version II is in discussion. I am trying to educate myself but it's hard reading info on various forums so i came here.
I am looking to hear opinion from someone that already tried this. So i have few question.
My scenario is that i might need 96khz in near future. From what i understand one Multiface II operate normally up to 96khz. But i want to connect 2x Multiface II.
So i am seeing these old threads on various forums where people are able to connect two Multifaces (version II).
Do i understand this right.
1. I can connect two Multiface II interfaces with just ONE PCIe card but i will be able to use all 16 ins only if i use 44khz. Because for connecting and linking two Multiface II interfaces i need ADAT connection between them. ADAT operates on all IO only at 44khz right?
2. Is there some other way, other then ADAT connection, to connect/link two Multiface II cards?
3. Is there some drawback on this? I found some info where people claim if i do it this way i will have to leave second Multiface II always ON 24/7 to not loose some connection settings something like that. Seems weird though.
4. Am i able to use this scenario (two linked Multiface II) on Win10 x64? Are latest RME software goodies also available for Multiface II?
5. Is it true that if i want full 16 IO by linking two Mutliface II at 96khz i need two separate PCIe cards? If this is true, this is not a problem for me but i want to know how does my DAW software see this? Do i have then like one ASIO card presented to software (because it is linked), or i see two separate ASIO interfaces in my DAW - in which case i am confused how does people use other inputs from other Multiface II then because ASIO AFAIK can see only one interface at a time...
6. MIDI - by connecting two interface do i also get two MIDI IO? Via one card or via two cards?
7. Can i connect Multiface II to Babyface Pro?
I hope to see some answers. If you have some links from this forum please share.
