Topic: Faders jump to 0 when DAW sequence is stopped/rewound
Hi.
I've used TotalMix for a while with a fireface400 without any issues. I use it with Cubase and Digital Performer running Windows 7 with a MotifXF 8 workstation / sequencer.
I had Total Mix set so that the Hardware Input Faders remained at the same levels during recording and in between projects.
Something changed in the settings when I switched from Cubase to DP8 this time. Now, hardware inputs from the Motif (AN 7 & 8) revert back to 0 when I stop and rewind in Digital Performer. The Main Out is set to AN 1&2 for the monitors. I can hear the audio signal and record it in the DAW.
How can I save the settings so they remain at the desired level without having to reset the level everytime I stop or rewind a sequence in DP8? Embarrassed to say I've spent several hours on this and can't find a solution.
Any suggestions will be greatly appreciated.
