51
Re: Latest Driver Updates USB
Windows USB driver 1.088 is now available. News:
- ASIO: MMCSS switch did not work since driver 1.036. Please retest your DAW whether this option on or off gives any benefit. To change issue an ASIO reset.
- ASIO: Added MMCSS support for Windows 10
- ASIO: Number of simultaneous hosts in multiclient operation raised from 4 to 8
- ASIO: bugfix multiclient hosts did not free their slot on exit
- ASIO: improved start/stop routines now allow to change the sample rate on-the-fly even between single, double and quad speed
Mac USB driver 2.16 is now available. It comes with TotalMix FX 1.21. Several new features also require a firmware update. Both together gives an impressive list of new features and improvements:
- CRM channel selection no longer limited for Fireface UCX, UFX, 802 and MADIface XT.
- selection dialog improved to prevent select-confirmation already on the first mouse click (example: Reverb - Type)
- the View Options panel can now be collapsed like all the other panels, thus getting more and flexible space
- as with the iPad app, the FX panel can now be opened by clicking on the round DSP meter. The View Options therefore can indeed stay closed after selection of the basic settings.
- many small code improvements and fixes for possible bugs and pitfalls
Add all the new features of our FX section, 8 new reverbs, improved sound and more new options that were already listed here:
https://www.forum.rme-audio.de/viewtopic.php?id=22978
and you should feel like you just got an after Christmas present smile
And there is more: Fireface UCX, UFX and 802 now support Loopback and EQ+D for record in CC mode. To be able to use this we have a new TotalMix FX for iPad in the loop (version 1.31) which will be available soon in the App Store.
All our USB 2, 3 and Class Compliant interfaces are now compatible to the Corning USB 3 optical cable. While it also works with USB 2 and CC its biggest advantage is with the MADIface XT and USB 3, as the cable gives looong length plus 100% performance and compatibility, whereas buying a stock USB 3 cable is always like lottery - and short.
Here are the links:
https://archiv.rme-audio.de/download/dr … ac_216.zip
https://archiv.rme-audio.de/download/fut_usb_mac.zip
https://archiv.rme-audio.de/download/fu … ce_mac.zip
Have fun!
Windows driver version 1.090 is now available. It inlcudes TotalMix FX 1.21 with the above changes (new Reverbs and CC features), and similarly requires a new firmware for UCX, UFX and 802. Links:
https://archiv.rme-audio.de/download/dr … n_1090.zip
https://archiv.rme-audio.de/download/fut_usb_win.zip
Windows driver 1.091 fixes a small memory leak and includes TM FX 1.22, where reverb type Space also works on the Babyface and Babyface Pro.
Mac driver 2.17_2 equals 2.17, but includes TotalMix FX 1.22 with the above reveb type Space fix.
Windows driver 1.095 adds digital signatures for Windows 7, 8 and 10. Note that on Windows 7 you need to have the latest updates installed or the driver will be shown as not being digitally signed.
https://archiv.rme-audio.de/download/dr … n_1095.zip
Windows USB driver 1.097 not only includes TotalMix FX 1.35, but can now also be installed and will work with any version of W7, 8.0, 8.1 and 10, no matter if updates etc had been installed for the OS or not.
The same applies to the new MADIface Series driver 0.9583.
Windows (1.098) and Mac (2.20, 3.01) USB drivers have been updated with TotalMix FX 1.40.
The new firmware for UFX II, USB 15 DSP 10 CC6 is now available.
News:
- Display changes to Volume screen when changing Volume at the host, also via ARC USB connected to the computer
DURec news:
- Recorded wav files now include meta data in iXML standard, mainly recording device, date and time, track count and channel info.
- To keep and make use of this info an updated Wav File Batch Processor is also available (see forum post about TotalMix FX 1.43). This version names the generated files according to the original record channel. For example UFX 00_I_05.wav is a recording of input channel 5. The updated Processor also writes the respective iXML data into the output files.
- Added new play modes: Repeat single, Repeat all, Single next (plays the current track and switches to the next one without playing it).
- Added new transport buttons: Previous file / Next file. These are shown in playback mode instead of Del and Record. With Pause active Previous/Next works without starting playback.
- Improved compatibility of DURec playback function
- New functions Next/Previous added for stand-alone operation with  ARC USB (buttons Snap 7 and Snap 8)
To use the new DURec features under Windows / Mac TotalMix FX 1.43 is available as beta in the TotalMix FX forum.
The new Mac USB drivers 2.21 and 3.03 with TotalMix FX 1.43 are now available for download on our website.
New firmware for UFX II, DSP 11 (same new functions as in UFX+):
- DURec with ARC USB: Stop of the recording now requires to hit the Stop button 2 times.
- Extended timer to stay in DURec screen after connecting the USB record medium
Mac Sierra/High Sierra USB driver 3.08 is now available, fixing dropouts/interrupted audio in specific cases, despite only medium CPU load.
Windows USB Series driver 1.164 has been released. This version finally retains the speaker configuration from the Sound control panel after reboot, and fixes several format compatibilites under WDM usage from the previous driver versions.
Mac Sierra, High Sierra and Mojave USB driver 3.10 has now been moved from the forum to the website.
3.10 includes some improvements and an updated TotalMix FX 1.52, but does not fix the audio problems on current MacBook Pro 2018 models as reported here in the forum, this needs to be fixed by Apple.
New in Version 3.10
- Added workaround for lasting distortion caused by insufficient USB handling of the OS (momentary glitch sound instead)
- Added network driver for the Digiface Dante
- Changed launch agent to 64 bit
New in TotalMix FX 1.52:
- Added support for Digiface Dante
- OSC can be set to support up to 48 channels per bank
- Starting DIGICheck by opening a DIGICheck file could cause it to crash
- Under 10.13 the About dialog was invisible
- Fixed possible crash caused by the mismatch message when using more than one interface
- Dragging a channel fader now requires to position the mouse on the fader knob
- In 2-Row mode the divider between Input and Playback row is no longer moved when opening the FX panel
We found a bug in our USB implemenation that prevented record to start with Asmedia USB controllers. Affected were UFX, UC, UCX, Fireface 802, MADIface XT and MADIface USB - sometimes not at all, sometimes only in specific combinations, and mostly on Macs. A new firmware is available that fixes this issue. Flash tool is available on Mac and Windows.
Mac USB driver 3.15 including TotalMix FX 1.6 is now available for download.
TotalMix Remote for Mac and Windows is now available in version 1.10.
Mac USB driver 3.16 including TotalMix FX 1.61 is now available for download.
macOS 10.15 drivers are now available as preview for testing:
https://www.forum.rme-audio.de/viewtopic.php?id=29107
macOS driver 3.18_3 has been released on our website. It brings back compatibility to 32 bit mode of the MIDI server.
Firmware version 125 is now available for the Babyface Pro, Mac and Win. As Babyface Pro and Babyface Pro FS share the same firmware the Pro jumps from 101 to 125. This firmware improves SteadyClock on both units.
