1 (edited by base2 2018-06-18 04:33:27)
Topic: [Solved] Macbook Pro 2017, Babyface Pro, USBc Adapter
Can someone point me in the right direction for an adapter that works? Right now my MBP isn't recognizing the BFP. I searched on the forums but there were so many osx/firmware issues, I wasn't able to find a solid answer on which adapter people are using.
Currently 10.13.5, BFP 3.08/101, Apples USBc to USB Single Adapter
Re: [Solved] Macbook Pro 2017, Babyface Pro, USBc Adapter
That adapter works. What does 'not recognizing' mean in detail?
3 (edited by base2 2018-06-18 05:44:16)
Hey!
The BFP lights up, but then is never selectable through the mac's audio system preferences, as well as total mix/bfp settings does not open.
What does it show when it lights up - PC or CC? Did you 'Allow' the driver?
5 (edited by base2 2018-06-18 06:04:56)
It actually opens with the top two lights lit orange, and then the next two lights lit red (no cc or pc), and the output side 'clip lights' light up red. Yes I allowed the driver the first time I installed the drivers. Now when I try to reinstall them, it doesn't ask
6 (edited by base2 2018-06-18 06:08:26)
I found that it was unchecked in security settings. Thank you for the help, everything works now
