Topic: Foobar and ADI-2 Pro FS relationships
Hello.
A week ago I become a lucky owner of ADI-2 Pro FS.
Sound is very good. But there is some inconvenience.
Еverytime, when I change the album with different sample rate (for example from 24 bit/ 96 kHz to 24 bit/192kHz), I must manually choose new sample rate from 'MADIface Series Settings', and choose manually the 'Device' in foobar.
Did I something wrong with installation/configuration/purchasing 'too hi end product' for a 'just a guy'?
Re: Foobar and ADI-2 Pro FS relationships
Please do not use WASAPI. Please use the Foobar2000 ASIO-Plugin and the MADIFace ASIO driver.
RME WASAPI does not support auto sample rate.
Hello again.
I am using the Foobar2000 ASIO-Plugin and the MADIFace ASIO driver nowadays.
No inconvenience anymore.
Still very good sound.
Thank You!
I'm also using ASIO plugin with foobar and works like a charm. Haven't yet really found a good use for WASAPI...
5
You need Wasapi for example with Tidal, which doesn't support ASIO (unless you use it within Roon). Solution for that comes tomorrow.
Here:
https://www.forum.rme-audio.de/viewtopic.php?id=27280
