Topic: IEM output suitable for RHA CL1 IEMs with 150 Ohm impedance?
Can the IEM output of the ADI-2 DAC drive those IEMs? Or do I have to use the 6.3mm output, risking to inadvertently blowing them up?
Would you advise against the RHA CL1?
Edit: sensitivity 89db, max. input 50mW
Will I hear more noise if I use the 6.3mm output in low power mode?
