Topic: UCX : Is there a device to have all I/O accessible from the rear?
Hello!
I am in the midst of setting up a tt patchbay at home with my fireface ucx and portable devices stacked on top. After building a custom db25 cable to reach the front of the ucx panel I determined the wrap around TRS cables were too intrusive.
Question:
Is there a device that will let me rout the front inputs (DA 1 to 4) and outputs (DA 7 and 8) to the rear of another module or break out cable? I am trying to bypass the front of the ucx while still having access it the I/Os. I do not need the built in 48v functionality if that helps.
Thank you for any tips!
MNM
