1 (edited by po 2018-10-26 03:00:10)
Topic: Fireface 800 - OSX Mojave - no audio input
After upgrading from El Capitan to Mojave (no clean install) there is no audio input from a Fireface 800 to DAWs (Logic, Max, Bidule). Output from DAW works, routing directly from input to output via Totalmix works also. But the computer gets no signal from Fireface 800 inputs, neither analog (line) nor ADAT.
MacBook Pro Mid 2012
OSX 10.14 (Mojave)
Fireface Settings Version 3.35
Unit #1A752812 v2.77
Kernel driver v3.35
Totalmix 1.5 (according to Finder info, Totalmix does not show it's "About" screen)
Any hint to get audio input again?
Re: Fireface 800 - OSX Mojave - no audio input
Did you enable the Mic input in MacOS?  System Preferences → Security & Privacy → Privacy → Microphone → DAW...
3 (edited by po 2018-10-26 13:31:24)
Thank you very much, these new Mac security/privacy settings were the culprit.
Input works again.
Problem solved.
(Of course I clicked "No" every time I was asked about using the microphone, I never use the internal mic. Did not think about audio input in general, rather thought they wanted to talk me to this dispensable Siri girl ...)
