Topic: RME UFX 1 Front Panel Inputs
I searched the forums and was not able to find the answer. Sorry if this has been asked before.
I'd like to know the difference in signal flow through the RME UFX 1, if I route a TRS cable vs TR cable vs an XLR cable using the front panel inputs.
I have 3 scenarios:
Scenario 1: I'm using a balanced line level (+4) instrument & trs cable.
Scenario 2: I'm using a balanced line level (+4) instrument & xlr cable.
Scenario 3: I'm using an unbalanced line level (+4) instrument & tr cable.
What is the difference in signal flow inside the UFX for these 3 cases?
Do I bypass the UFX pre-amps or do the front panel inputs always use the UFX pre-amps?
Should I be using the rear panel jacks instead for the above scenarios?
