1 (edited by dir 2018-11-08 11:31:17)
Topic: Jitter issue on the INT clock
I was looking for behaviour of some digital transports on optical input of RME ADI-2 Pro FS.
I was notice a significant jitter raises when I set clock to INT + SRC SPDIF. It even worse than Airport Express as master.
Arta and MusicScope software are used as measurement software in 24 and 16bit modes.
Airport Express (Clock SPDIF, SRC-off):
http://i.piccy.info/i9/d52413f6802900a3550e8bf97edc8c3e/1541629362/45273/1274225/clock_spdif.png
http://i.piccy.info/i9/86c36d4aaaee2e49d6022f6417bebdf0/1541629501/40093/1274225/clock_spdif_.png
Airport Express (Clock SPDIF, SRC-on):
http://i.piccy.info/i9/4427d99efa9169ebbc08bfda48f84e40/1541629582/27961/1274225/clock_spdif_src.png
http://i.piccy.info/i9/b382d3bd07cdefb5bd1a5236cef17256/1541629840/41413/1274225/clock_spdif_srs_.png
Airport Express (Clock INT, SRC-on):
http://i.piccy.info/i9/f578beeeaef5b19d9379197261b33581/1541629995/29500/1274225/clock_int_src.png
http://i.piccy.info/i9/f089c98291e914f2732659560a118569/1541630048/46774/1274225/clock_int_srs.png
It looks same on other digital transports. Its a wrong mode maybe or I doing something wrong?
Re: Jitter issue on the INT clock
I have no clue what is going wrong here, and I can not reproduce these measurements.
Here is an iPad playing back the 11.025 kHz sine via a UCX in CC mode over SPDIF into the ADI-2 Pro. With external clock or SRC off the measurement looks perfect. This pic is the worst I could produce.
I also still have no clue what all this is good for, or what it is supposed to show.
http://www.rme-audio.de/images/ipad_spdif_src_int.png
3 (edited by dir 2018-11-09 21:21:40)
I was got all these pictures from SPDIF-in on ASIO inputs, not analog
Is it possible that I just have non-FS version with higher jitter? Because my paper box stll have old design without FS signature
Obviously my measurement is also SPDIF In, not analog (noise floor down at -170 dBFS with analog?).
If your front plate says FS then you have one. And your first two measurements look like that as well.
Thank you for your feedback. It is understdood that your measuerments was made in digital domain.
I just want to understand the differences between the modes. As far as I understand, the SRC is a prerequisite mode when turning clock to Int? When I try to record the 11 kHz jitter tone in the (Clock INT, SRC-on) mode, the level begins to "float" as a modulation product. The status of the signal was changed to 24 bits on RME display, although 16 bits are supplied though AES-in. This is not all there is if clock was switch to AES and SRC was turn-off.
http://i.piccy.info/i9/5040c1737568ddcc2384a675f7e9c42c/1541934537/22191/1274225/Untitled_1.png
