Topic: BO-968 AES/EBU with 9652?
Can anyone tell me if BO-968 AES/EBU is compatible with 9652?
Which are the compatible choices for the 9pin connector to these cards?
2 (edited by ramses 2018-11-30 16:36:34)
Re: BO-968 AES/EBU with 9652?
EDITED .. got the 2nd adapter wrong in the old post.
Look at the accessories page: http://www.rme-audio.de/products/cables.php#4
The breakout cable BO968 doesn't list your card 9652.
There is another breakout cable for your 9652 card available (EDITED: BOHDSP9652)
You can see in the pictures of the accessories webpage, that the breakout cables have different types of i/o.
So you require BOHDSP9652 for your 9652.
https://www.dropbox.com/s/19nwanexz3crdb8/2018-11-30%2016_19_27-hdsp9632_e.pdf%20-%20Adobe%20Reader.jpg?dl=1
https://www.dropbox.com/s/w3dyqsmdac4eyjr/2018-11-30%2016_32_15-RME_%209652%20Adapter.jpg?dl=1
Thank you for the reply ,
the 9652 does have a 9 pin port which is what the B0 968 uses as well ,
they both have spdif I/O only difference is the second connector D-sub vs AES . Im only interested in using the spdif connection thats why I asked .
4 (edited by ramses 2018-11-30 16:40:57)
You could have said this directly wink
In a good case of luck you should be able to see the pinout in the handbook.
EDITED: sorry no, see my last post #6
Thanx for your help ramses!
6 (edited by ramses 2018-11-30 16:45:18)
I looked for you into the handbooks.
The pinout for the 9632 card's 9-pin D-type connector (cable BOBO968) is described in the manual, see chapter 34.2.
https://www.dropbox.com/s/0wbbpp0qw9fjkmv/2018-11-30%2016_37_47-hdsp9632%209-pol%20pinout.jpg?dl=1
But the pinout is missing in the 9652 card's manual for the BOHDSP9652 breakout cable. I also looked at the old DIGI cards handbooks (DIGI 9636, DIGI 9652), but also there no pinout for the 9-pin connector included.
So this can be answered only by RME.
7
ADAT Sync connector
Pin   Signal             Pin     Signal
9      SPDIF In +       5       SPDIF In -
6      SPDIF Out +     1       SPDIF Out -
They are not compatible.
Thank you all for the responses!
