orbiterred wrote:I guess another question would be... upgrading to a bigger RME interface, would it run more plugs at 128ms than the BF Pro?
The plugins run on your PC's CPU. Your PC is currently not capable to transport audio in time.
Changing the interface does not solve the root cause.
Now you have a BBFP with only 12 I/O. If your PC with it's current settings is unable to transport 12 audio channels, then it won't become any better, if you would take i.e. an UFX II with 30 i/o channels.
You could eventually have a little bit more luck with an PCIe based interface because PCIe has a little bit less CPU overhead. But I do not think that there will be much difference. It's more likely that also with PCIe you will have issues, because something with your PC is wrong. There is not enough headroom for your CPU to be able to deal with audio in time.
The forum colleagues already gave you some good tips into the right direction.
BIOS energy saving settings can cause a severe lag which brings audio to fail. These are the 250-500 us which are missing to process audio packets in time.
Another thing is that Windows has CPU core parking enabled. This also generates some form of delay.
Additionally I recommend you to disable CPU core parking if you have a Desktop PC.
On a laptop I am nor sure whether it's a good idea because I fear the Laptop could get thermal issues.
Another thing to look for is whether you have thermal issues and the CPU starts to enter lower clock.
