Topic: Should XLR Ref level show +1 to +19 Db?
I switched from RCA to XLR (HIGHLY recommend this - geez what a difference! Your system isn't at near its full potential without balanced connections).
Anyway, I'm liking the sound a LOT (almost too powerful but sounds amazing)... my question is, in the manual, it suggests XLR Ref Levels are +6db higher than RCA... going up to +19. However, my max is still +13, even after resetting all settings by holding volume and 2 in while restarting.
Should I be seeing a +19 option in ref level?
Re: Should XLR Ref level show +1 to +19 Db?
No. The unit doesn't know you plugged in XLRs or RCAs, so the display doesn't change.
Thanks. So XLR is just 6dB louder at any particular volume setting than RCA?
Yes.
