dmail wrote:Hi all,
I have an ADI 2PRO unit wich is very good.
I'm upgrading my tracking / mixing system to MADI with a digiface USB but it has only one MADI port (and only 32 tracks @192Khz). I'm considering to replace my digiface / ADI 2PRO combo by a Digiface XT to have more inputs.
I would like to know if the Digiface XT use the same quality DAC and ADC as the ADI2 PRO?
Thank you.
Keep your ADI-2 Pro it has best AD/DA conversion as mjfe87 already mentioned.
BTW ... you can combine your ADI-2 Pro with any other RME interface by using a digital connection.
See also my blog article: https://www.tonstudio-forum.de/blog/ind … our-Setup/
Could you be so kind and edit your request to use proper product names ?
It would really help to be able to give you a good recommendation at all.
It would also be useful if you could detail which port types you need or what is missing at the moment.
