Topic: M/S processing on TotalMix Playback/Outputs?
Hi everyone!
I was wondering if it's possible to encode a stereo L/R playback program to M/S with TotalMix, so that the M-signal goes to hardware output 1 (for example) and the S-signal goes to output 2?
That way I could feed an M/S signal into a dual-mono EQ that I have and have each channel process thing differently.
Is this possible to do this with TotalMix?
Or does TM only does M/S encoding on its inputs?
Re: M/S processing on TotalMix Playback/Outputs?
Do a physical loopback (SPDIF or ADAT) and use the inputs to do that. Then route that signal to the outputs where your EQs are connected.
That should work!
Thanks, Matthias.
Best regards,
André
