Topic: Are there tiny noise Fireface400 S/PDIF direct?
Hi, I am Fireface400(FF400) user and I have utilized it about 10 years for my development.
In my development, I often uses S/PDIF port connected with my development board.
But recently, I notices tiny noise when I connected FF400 S/PDIF out -> S/PDIF in directly.
Although the noise level is very small, less than -150dB, I want to remove it if possible.
And the noise is not appeared at HDSPe AIO in same PC and same VST host.
So I wonder Fireface400 generates the noise.
Do you have any information?
Best,
Takeshi
- summary of my environment
PC : Win7 Pro Service Pack 1 64bit (Core i7-6700K 4GHz / 32GB RAM)
VST Host : LiveProfessor2.20 64bit
Re: Are there tiny noise Fireface400 S/PDIF direct?
You either did not use ASIO, had the TM FX faders not on 0 dB, or recorded with TMS active.
Thanks for your quick reply!
Yes! "TMS active" is the origin. After I turned off TMS active and reboot PC, noise is  disappered.
I also checked TMS has turned off in HDSPe AIO setting.
Best,
Takeshi
