Topic: ARC & key command settings dialogue doesn't appear
As the title says, when I click the "ARC & key command settings" option in TotalMix FX - nothing happens.
Please help.
Fireface 802. MacOSX 10.13.3
RME User Forum → FireWire & USB series → ARC & key command settings dialogue doesn't appear
Please help.
Which TotalMix FX version is that?
You could also start the Console before starting TM FX. Then try to open the dialog. If that fails a message should be found in the console.
I had the same issue a few times. Using total mix 1.6. beta 1 on Mac OS 10.13.6.
Restarting Total Mix did the trick for me and I was then able to configure the ARC USB.
Problem reappeared but a Total Mix restart always solved it.
This was with Version 1.52 MAC OS X (1)
The problem appears to have corrected itself. Thanks for your help.
