Topic: HDSPe AES vs HDSPe RayDAT
AES has 16/16 channels vs 36/36 for RayDAT and yet AES is 30% more expensive. What makes AES that better?
Thank you in advance!
RME User Forum → HDSP(e) series → HDSPe AES vs HDSPe RayDAT
Not better, just different connection. Apparently optical connectors 4 in 4 out is cheaper to make then coaxial 8 in 8 out. Could also be in numbers, maybe they made 10.000 raydats and 1000 AES's. Just my thoughts.
Maybe ADAT circuits are cheaper, because it's also being used in consumer devices.
AES is more special, it's a studio standard.
And .. with ADAT you loose channels by multiplexing (with higher sample frequencies).
4x8 = 32 @48 kHz
4x4 = 16 @96 kHz
4x2 = 8 @192 kHz
For the HDSPe AES card the amount of channels stays the same (16 IN and 16 OUT) up to 192 kHz.
Requires maybe also other treatment / performance.
Thank you, ramses.
Thank you, MC. And Vincent!
