Topic: ADI-2 Pro power-off light ring
Can't find anything wrong in the ADI-2 Pro. It's a joy to use, no less, and even more to listen to.
But when I switch it off, that red ring lighting up around the power button is the only thing I wouldn't want to see on it.
It makes it stand out from afar, and in the dark, too, like the stupid operator forgot to switch it off when he left.
Besides... I often sleep here, too, and it watches me... spoooky!
The way my ADI-2 Pro is rigged, I can't access the back panel easily (hence I cannot easily remove the DC IN locking connector), nor I can wire a separate powerline with a separate power switch just for the ADI-2 Pro, as there are pieces of equipment that need power to perform backup operations even when in semi-off mode (with all front LEDs off).
I'm sure you can easily find hundreds of honest users, here on this forum, who might think this red LED ring lighting up when the unit's off is a neat feature, and this proves we're not all going in the same direction at any given time. Want the guy who has disabled all ports' LEDs on the nearby Cisco SG300 network switch, in order to cut on AC mains power unnecessary waste? OK, you've found him, and I hear people calling this futile every two days (or even one), but still...
Any chance that it can be simply un-powered while in power-off mode from a setup setting, in a future firmware update, please?
Like a "Support the Kyoto Conference Resolution for a cleaner future?" statement? :-)
