Topic: Is there who use ADI-2 Pro FS as ASIO audio interface on Cubase?
I plan that buy ADI-2 Pro FS as ASIO audio interface on Cubase.
But I do not know latency.
I want know latency varue of VST Audio system panel on Cubase.
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → Is there who use ADI-2 Pro FS as ASIO audio interface on Cubase?
On Nuendo reported by ASIO driver:
ASIO Buffer size: Input- / Output- / Total Latency (@44.1 kHz)
32 samples: 0,930 + 1,995 = 2,925 ms
128 samples: 3,107 + 4,172 = 7,279 ms
256 samples: 6,009 + 7,075 = 13,084 ms
You can do it this way but you need to consider, that everything has to be routed through the DAW.
For "near-zero" latency monitoring capabilities I would recommend to choose a combination
of recording interface with TotalMix FX and the ADI-2 Pro FS ADDA converter.
See also these two blog articles that I wrote around this topic:
https://www.tonstudio-forum.de/blog/ind … ort-DE-EN/
The cheapest way would be using the Digiface USB as recording interface.
Thank you.
It was very helpful.
I have a same plan as himaizumi:
I've been thinkin' to replace my current audio interface with ADI-2 PRO FS. I also have Cubase as my DAW. And as I already have Avalon preamps I don't want to buy any audio interface (w/ preamps) to be able to record with near-zero latency.
So, my question is: is it possible to connect either RME HDSP 9632 or 9652 (what's the difference?) to ADI-2 PRO FS, and if so, how?
Cheers,
Jo74
You connect adi-2 pro fs to a digital port of the pcIe recording interface.
Like described in my blog article see my previous posting (#2) with the 2 URL's. I assume you didn't read it.
Cheers,
Jo74
9652 3 adat and 1 spdif
9632 1 adat 1 spdif and stereo analogue in and out
I have both
