1 (edited by garfield 2019-05-14 03:12:57)
Topic: Hiding single channel hides it's partner - normal behavior or bug?
This is my setup:
OSX 10.11, Digiface USB with 3x ADI-8 DS, was on most current drivers and today tested with latest 1.60 beta
I'm routing a software output to three channels: ADAT 6 (mono), and ADAT 7/8. ADAT 5 is not in use.
Since I don't need ADAT 5, I open the Channel Layout menu, and hide that channel on the mixer/matrix and remotes.
Doing this hides ADAT 5 on the mixer and matrix, as expected. However, it also hides ADAT 6 from the mixer routing destinations in Mixer view. Matrix view works correctly.
Software Playback Destinations before:
ADAT 1/2
ADAT 3/4
ADAT 5
ADAT 6
ADAT 7/8
etc
After hiding ADAT 5, I expect to see destinations:
ADAT 1/2
ADAT 3/4
ADAT 6
ADAT 7/8
etc
but what shows up:
ADAT 1/2
ADAT 3/4
ADAT 7/8
etc
ADAT 6 still appears on the hardware outputs. In Submix mode, if I click on hardware out ADAT 6 it will say "ADAT 1/2" on the software output destination, but still adjusts ADAT 6 correctly. It doesn't matter which pair I have the mono channel hidden on - it always says 1/2, but adjusts the correct channel. In Free mode, it's impossible to access ADAT 6 in this situation without using the matrix.
The opposite: If ADAT 5 and ADAT 6 are mono, and I hide ADAT 6, ADAT 5 is still visible and will focus as a playback destination correctly in Submix mode. ADAT 6 still appears as a destination on the software playback channels, but we cannot access ADAT 6 from the mixer OR matrix.
ADAT 1/2
ADAT 3/4
ADAT 5
ADAT 6
ADAT 7/8
etc
After hiding ADAT 6, I expect to see destinations:
ADAT 1/2
ADAT 3/4
ADAT 5
ADAT 7/8
etc
but what shows up:
ADAT 1/2
ADAT 3/4
ADAT 5
ADAT 6
ADAT 7/8
etc
Does the above make sense? Basically, If I hide one of two stereo channels, submix mode displays either the wrong channel (always ADAT 1/2 of I hide the odd channel) or doesn't hide the channel as a destination (the even channel is always visible as a destination, but not in the mixer or matrix).
EDIT: just to be clear, this happens across the hardware input destinations, as well. This happens anywhere you can assign a destination.
I just want to hide a mono channel so I'm not wasting faders or screen space with outputs I'm not using smile
Thanks for any help!
Re: Hiding single channel hides it's partner - normal behavior or bug?
The list has an internal reference to the left channel of a stereo pair. Removing that removes the entry completely. That's not a serious problem, as you can stilll click on the remaining mono output channel to select the routing destination (Submix mode).
Thank you, Matthias. Yes it was just unexpected, but not too concerning.
So far I love Totalmix! After using it for only a few weeks I've replaced my 16ch/6aux/8bus mixer and two patch bays with Totalmix + a Mackie MCU Pro, and everything wired direct. Soon I will switch from the Digiface USB to an 802 or UFX since I need a few preamps and would like to have the DSP.
