Topic: Problems with the regulation of volume and panorama on RME BABYFACE PR
Hello ! I have an important question about the USB interface RMS Babyface PRO.
For a number of reasons, I often need to very precisely adjust the value of panning on the outputs, primarily headphones. Suppose that in 90% of cases the optimal value on the controller in the driver (MAIN for headphones, but the same thing happens on analog outputs to studio monitors) 7 or 9. With software volume control these values remain the same. But as soon as I start to turn the volume wheel on the device, they switch to 6 or 9. If the value is 17 on the same right channel, then it automatically changes to 21 if I touch the volume knob. Tell me what to do? Panorama hardware, as I understand it, can only be adjusted while the Select button is held on the device. The function Total reset in the driver does not help, it only resets the volume settings on the channels. Previously this was not.
With deep respect, Vyacheslav.
