Topic: ucx fx return bleedin
Hey hows it going,
trying to record some fx with ucx
i’ve sent audio from a machine drum to inputs 5-8 on the ucx
i’ve routed that audio to adat outputs 3-6 - and
i’ve initiated loopback and turned the fx return up on all adat outputs and am recording them into daw on 4 separate tracks
the problem is I can’t seem to record more then one input with the fx wet without the gain fx returns bleeding over into the other tracks. Is there any way I can stop this from happening and have more then one channel with a wet fx signal without the bleed. ?
thanks
dodec’s
