Topic: ADI-2 DAC: Slow filter at higher sample rates
I am interested in using the Slow filter option on the ADI-2 DAC for its good impulse response, but the rolled off treble in the audible range and imaging down to pretty close to the audible spectrum when using 44.1 kHz sample rate is not what I want.
Is this something that can be cured by upsampling my music to say 176.4 kHz and then also using the DAC at this sample rate? The manual only shows frequency response for 44.1 kHz, so I don't know what happens at higher sample rates.
I am also a bit unsure about the lowest possible image frequency in this case. I think it would be 154.05 kHz (sample rate 176.4 kHz minus 22.05 kHz as the highest possible frequency in my source files), would the DAC even be able to output that?
Also, would impulse response somehow get worse again when upsampling?
Re: ADI-2 DAC: Slow filter at higher sample rates
I fully agree, but in the end the aliasing turns out to be no big issue in real-world...otherwise MQA wouldn't even exist...
And for the rolled-off treble there is a simple workaround: use the EQ to compensate. Here are two settings for Slow and NOS to linearize the treble response at 44.1 kHz sample rate:
Slow B5 G +4.0 F 16.5k Q 2.1 Shelf
NOS B5 G +3.0 F 14.3k Q 0.6 Shelf
As you can imagine with only 3 and 4 dB gain this is just a slight change, it linearizes NOS perfectly, and Slow good enough.
http://archiv.rme-audio.de/images/dafiltercurve_eqcomp_slow.png
http://archiv.rme-audio.de/images/dafiltercurve_eqcomp_nos.png
Now the point is that the Shelf filters have only small impact on the impulse response. Basically Slow stays Slow, and NOS stays NOS. See these two pictures, comparing original (red) with EQ'd (blue) result.
http://archiv.rme-audio.de/images/slow_eqcomp.png
http://archiv.rme-audio.de/images/nos_eqcomp.png
From single to quad speed (up to 192 kHz) the filters stay the same, they just double/quadruple in corner frequency (they move out of the hearing range), and the ringing is halve/quarter in time length.
Above 192 kHz the DAC always uses Slow, this is a fixed function.
But the point is a different one: whenever you upsample the data has to be filtered. This filter is exactly the same as when using the DAC itself in Single Speed, and can also be seen in the upsampled result. So you gain nothing.
At 192 kHz there is no real argument against a steep filter, no matter if SD Sharp or Sharp. There will be no 96 kHz signal in your audio material that would make them ring. And even if then you are not able to hear this short, low level 96 kHz signal.
Thank you for the EQ settings. I will test them once my unit has finally arrived. I thought the treble roll off was important in getting the impulse response, but this looks very minor.
Am I correct to assume the settings for the Slow filter will also work for the SD Slow filter, given their frequency response is virtually identical up to 20 kHz?
Correct.
Yes, peak filters usually cause more ringing than shelf filters when used in an application like this one, correcting the frequency response near the Nyquist border.
6 (edited by dir 2018-05-04 19:05:53)
any EQ-recommendations for 48 kHz, 88 etc (in the NOS-mode)?
it will be interesting to EQ-correct input for recordings with slow filter
7
At 88 kHz there is no need to correct NOS anymore, IMHO. And the record EQ setting is exactly the same for Slow as shown above. For 48 kHz I will check.
http://i.piccy.info/i9/9b202991a0c2ed0793eb196a0fe46ac1/1525517191/19176/1239453/Spectrum.png
24/96 mode
it drops a little (around -1 dB) on the 24 kHz band
by the way, why RME calls super-slow filter of 4490 as NOS ? Actually NOS-DAC's are differrent story.
9
Explained in the manual. Seeing the stairsteps and the massive aliasing effects it is bad enough to be called that (the reason that we made it available at all is that the oversampling is reduced, but not completely gone. Therefore the filtering is still there, weaker than with Delta-Sigma, but more than real NOS. It's an interesting approach, and the side-effects are tolerable in certain applications).
But the point is: the Pro is a Pro tool. Calling a filter 'SuperSlow' has no meaning for anyone. Imagine someone transfers precious recordings through an analog chain, uses the Pro (or DAC) as DAC, processes it, records it again at Hi-Res. Then a year later the engineer discovers that all transfers are completely messed up with high frequency noise, aliasing, and even the expected response in the higher treble lacks. Then that guy is fired and our reputation completely destroyed.
In HiFi people can do to the music whatever they like, it's their fun and usual has no serious consequences, right there at the end of the chain. In a studio environment R2R and NOS are an absolute no-go. So is 'SuperSlow'.
Here are examples for EQ settings to compensate Slow and NOS at 48 kHz sample rate:
Slow B5 G +2.5 F 16.3k Q 1.7 Shelf
NOS B5 G +3.5 F 16.5k Q 0.9 Shelf
As expected the higher frequency response of 48 kHz sample rate helps making the frequency response even more linear up to 20 kHz as with 44.1 kHz sample rate.
http://archiv.rme-audio.de/images/dafiltercurve_eqcomp_slow_48.png
http://archiv.rme-audio.de/images/dafiltercurve_eqcomp_nos_48.png
And here are the impulse responses for these EQ settings, comparing original (red) with EQ'd (blue) result.
http://archiv.rme-audio.de/images/slow_eqcomp_48.png
http://archiv.rme-audio.de/images/nos_eqcomp_48.png
Danke! This is really a very useful correction!
but what about the HD-signal? I must disable the EQ or will there be any presets for it, too?
12 (edited by HIFI 2018-05-17 06:59:38)
https://archiv.rme-audio.de/images/dafiltercurve_eqcomp_slow_48.png
https://archiv.rme-audio.de/images/dafiltercurve_eqcomp_nos_48.png
https://archiv.rme-audio.de/images/slow_eqcomp_48.png
https://archiv.rme-audio.de/images/nos_eqcomp_48.png
The simplest thing to set in the unit is setting the high and low frequencies. For Slow 10kHz to + 3.2db. For NOS 3.5kHz to + 2.5db. Get the same smooth frequency response up to 20 kHz.
13 (edited by PulsaR 2018-11-17 21:10:39)
Does the correction apply to "SD Slow" as well?
If not can we have correction data for SD Slow as well if it needs it?
I think you have an error in your ADI-2 DAC user guide v1.4:-
DA Filter
Short Delay Sharp, Short Delay Slow, Sharp, NOS. The Digital to Analog Converter chip offers
several oversampling filters. Default is SD Sharp, offering the widest and most linear frequency
response and lowest latency. SD Slow causes a small drop in the higher frequency range.
Should it not be:-
Short Delay Sharp, Short Delay Slow, Sharp, Slow, NOS. (Add Slow)
15
Thanks for the note (I had received your mail to Support already). Yes, the word 'Slow' is missing.
SD Sharp / Sharp and SD Slow / Slow have the exact same frequency response, so the EQ settings work for both.
Does the DAC require any EQ'ing for 96kHz>?
P.S I love this DAC, it has replaced my Chord Hugo 2!
17
The Slow and NOS filter do not need EQ at sample rates higher than 48 kHz, as the attenuation happens outside the hearing range then.
18 (edited by gioan 2019-01-27 11:01:06)
Is this point valid also for upsampled 88/96/176 etc. from original 44/48khz recording? (I suppose yes, but not sure...)
Also would be interesting to see (if you have) frequency responses of slow/nos filters at 88/96/etc. khz
All this stuff by a pure "technical" curiosity, not audiophile mumbo jumbo...
I'm perfectly happy with "textbook" sharp filters at any samplerate :-)
You should read post #2 wink
20 (edited by gioan 2019-01-28 18:58:57)
This parts, I assume:
"From single to quad speed (up to 192 kHz) the filters stay the same, they just double/quadruple in corner frequency (they move out of the hearing range), and the ringing is halve/quarter in time lengt".
and
"whenever you upsample the data has to be filtered. This filter is exactly the same as when using the DAC itself in Single Speed, and can also be seen in the upsampled result. So you gain nothing".
The underlined parts of the two sentences appear inconsistent in my view.
If the filters double/quadruple in corners frequency (they move out of the hearing range) (and, I assume, the frequency roll-off move out of the hearing range), then is not exactly the same....
Shure, my lack of knowledge...
21 (edited by jiw 2019-01-28 21:22:43)
As MC says in post #2, the upsampling filter does exactly the same as the DAC for single speed data: remove content above the single speed Nyquist-frequency.
Thus, the impulse response and frequency response are dominated by those of the upsampling filter.
If you upsampled using a slow (shallow) filter, the HF attenuation is similar to that of the DAC's slow filter and you will need EQ to increase HF extension.
Ah ok...you (and MC of course) mean the interpolation low pass filter (at single speed Nyquist frequency) in the upsampling process.
Right, my lapse of memory.
Excuse me.
If i understand correctly.
1. When use files whith sample rate 44.1kHz output must be equalized for high frequency dropdown reason.
Valid for Slow or NOS filters.
2. When use files SR 48kHz
3. Streams higher 192kHz have only slow filter by default.
4. 88/96kHz not checked.
Question.
If frequency response have audible dropdown with 44.1/48 sampe rate streams why dont implement correction in dac firmware? Why user must be do it itself. And next question. How to view dynamic status of this corrections when switched from different files. Example. User done eq correction for 44.1 next switch to 48 done it for 48, next play 192 ets. Its not good for home users. This is good for profi whith one type of files used in one session on DAW. Ones time set and working.
Maybe add this corrections to dac firmware?
Hi.
Thank you all for interesting topic. I'm still learning this superbeast machine and very happy to have one. Please forgive me my question but in EQ settings - what "Q" stands for?  What value is that, can someone explain me please?
Any link to read about appreciated.
It explains itself if you watch it interactively at the PEQ.
You change whether influencing a broad or narrow range of frequency to be modified by the EQ setting.
Indeed smile   Now I know.  Thank you Ramses.
Q=Quality Factor.     The Lower the "Q" the Broader Range of Frequencies affected.  Likewise, a higher Q filter affects a narrower range.   Easily observed on the PEQ Screen.
Curt
Cables:  Red, and White Ones.
Speakers:  Yes
I am really out of my league here.  But what I have found is that I like the sound of NOS filter for some reason.  However I don't like the HF roll off.  So I tried my own PEQ filter in order to correct the roll off.  I then found the one posted here for NOS.  I will try that shortly.  But my lack of understanding leaves me a little confused.
I am trying to get CDs to sound good at 44.1kH sampling.  So the filter published here  will correct the HF roll off.  But what happens when I stream USB at 192kH?  What effect will the filter have.  Do I have to turn off filtering?
Also, when I turn off PEQ and look at the EQ window, it still shows the EQ curve even though I think I turned it off.  There is no indication in the EQ window that it is off.  How am I to understand this?
Also is there some free software available for modeling PEQ curves?
Thanks.
29
1. At 192 kHz sample rate you need to turn the filter off manually.
2. EQ disabled - curve shown in white instead of different colours.
Thanks.  I see that now.  Should I be concerned about the audibility of aliasing using the NOS filter?
I see that you said in a previous post that aliasing was not a real-world issue.  As for 192k, what happens to the frequency response when the NOS filter is in place?  Does the filter get replace with a slow filter above 192k or exactly at 192k?
32
1. You will see a small raise in upper treble.
2. Above 192 kHz.
33 (edited by orangejello 2019-08-03 19:23:24)
Thanks.
BTW, I didn't find a mention in the documentation of the >192K filter always being "Slow".
34
Correct, I'll add  it.
35 (edited by zaurux 2019-08-04 14:47:39)
If i use upsampling under Roon from 44.1 and 48 to 88/96, there is an effect with slow and NOS? Less treble like 44.1 and 88 ?
ROON on Lenovo > Allo USBridge > RME ADI-2 Dac > Audia Flight FL100  / Recital Audio Define HEFA
Wow, thanks MC! I just stumbled across this post. Changing the EQ with the slow filter has absolutely changed my perception of the RME DAC.
Up until now, I enjoyed the SD SLOW filter, mostly due to the fact it sounded most natural and organic to my ears. It also seemed to open up the soundstage and made things sound motr three dimensional. However, it often made a lot of music sound undefined and thus homogeneous as well. The SD SHARP filter gave music the required edge to help dynamics and perhaps had better "musicality" too but at the expense of the qualities I enjoyed with the SD SLOW.
I spent weeks thinking the perfect scenario for me would be a half way point between these two filters. After applying your EQ changes, I've found that sweet spot! I get all the smooth, airy sound of the SD SLOW with the positives of the SD SHARP combined. It's genuinely amazing to me how much this has changed my enjoyment of the RME DAC. I no longer get up between songs to change filters according to what song I'm about to play.
And for 44.1 kHz:
Hello Matthias,
thanks for this great information. This would be even good to have it in the manual!
My question:
Can those EQ presets be used with ADI-2 DAC FS (ESS), too? The known frequency response for the DAC 2 FS e.g. shows a decrease for NOS / 44.1 kHz beginning at 6 - 7 kHz - but correction starts at 14.3 kHz (for ADI 2) - wouldn't this be a little late for the DAC 2 FS (I don't know the linear frequency response of the ADI 2 DAC to be able to do an own comparison)?
38 (edited by KaiS 2023-04-23 21:17:00)
The filters, except “Sharp”, even if named similar, have a different shape in the ESS vs.the AKM DAC chips.
It’s visible in the graphs in the according manuals.
So, different EQ’s are needed.
Thanks Kai!
Hopefully Matthias can create those EQs for the ADI-2 DAC FS, too?
I'm wondering if there is any (online) application, which simulates creating EQs. Here, you can create filters, but the Q factor is ignored for the type higshelf. Does somebody know any other sites maybe?
Im very interested to experiment with compensation filter for 44.1 an 48 kHz for NOS and Slow with my ESS version ADI-2 DAC.
@Matthias: Would it be possible to share the settings like above especially for ESS?
I find this comment to be a revelation.
I have a HEGEL H20 Class A/B dual mono Poweramp connected to Magneplanar 1.7i speakers. As a pre-amp I use the RME ADI-2 Pro FS R BE.
I noticed that the Sound was very cold and analytical using the default SD Sharp filter.
So, I decided to change the default setting in the AD Filter settings from default SD Sharp to Slow. The improvement in Sound Quality was stunning, I was flabbergasted how much the SQ improved so much: wamer, very pleasing to listen to, no listening fatigue anymore, gone with the cold and analytical sound.
I wanted to know more about WHAT and WHY the SQ improved, so I entered in ChatGPT 4o the following prompt:
"My RME DAC's DA Filter is set to SD Sharp. What would be the effect to change the Filter to Slow?"
This was the generated response to my prompt:
ChatGPT
Changing the filter setting on your RME DAC from "SD Sharp" to "Slow" affects the way the digital-to-analog conversion process handles high-frequency components of the audio signal, primarily influencing the trade-off between transient response and high-frequency noise rejection.
Here’s a breakdown of the effects:
1.    Transient Response:
SD Sharp (Sharp): This filter has a steep roll-off, which means it more aggressively attenuates frequencies above the  Nyquist limit (half the sampling rate). This results in better preservation of transient details in the audio, leading to a crisper and more defined sound.
Slow: This filter has a gentler roll-off, leading to a slower attenuation of high frequencies. As a result, transients may not be as sharply defined, potentially making the audio sound smoother or more relaxed.
2.    High-Frequency Content:
SD Sharp: The sharp filter cuts off high-frequency components more abruptly, which minimizes the aliasing and high-frequency noise but can introduce pre-ringing artifacts.
Slow: The slow filter allows more high-frequency content through, which can result in a more natural sound. However, it might also let through some high-frequency noise that the sharp filter would have attenuated.
3.    Overall Sound Character:
SD Sharp: Often perceived as having a more analytical and detailed sound due to the emphasis on precise transients and high-frequency attenuation.
Slow: Often perceived as more musical and natural, with a potentially smoother and warmer sound due to the less aggressive handling of high frequencies and transients.
4.    Listening Preferences:
    If you prefer a highly detailed and crisp sound with a focus on clarity and transient response, the "SD Sharp" filter might be more to your liking.
      If you prefer a smoother, more relaxed, and natural sound, the "Slow" filter might be more appealing.
      In summary, changing your RME DAC’s filter from "SD Sharp" to "Slow" will likely result in a smoother and potentially warmer sound at the expense of some high-frequency detail and transient sharpness. It’s a subjective preference, and you might find one setting more enjoyable than the other depending on your listening habits and the type of music you enjoy. Experimenting with both settings and listening to a variety of music will help you determine which filter suits your personal taste best.
      That is exactly what I experienced, a new listening experience, music reproduction on steroids.
      43 (edited by KaiS 2024-05-18 12:08:36)
      Wow, this had to happen sooner or later - have to argue with ChatGPT:
      A good example how ChatGPT mixes true and wrong assumptions it has collected from … - where?
      In short (@ 44.1 and 48 kHz sample rates only, irrelevant for higher SRs), for the AKM chip of ADI-2 Pro.
      Same named ESS filters are in fact different to AKM, except the “Sharp” ones, wich are relatively close.
      Sharp Filter (AKM and ESS):
      • Frequency response:
      Linear up to 20 kHz, sharp cutoff above.
      • Impulse response in the upmost audio band:
      Bad, unnatural pre-ringing, smeared transients.
      • Aliasing artifacts that can reach quite low into the audio band:
      Very few.
      • My subjective impression:
      Bad separation of percussive high frequency instruments, e.g. hihats and shakers.
      Some lack of ambient definition.
      Slow Filter (AKM):
      Soft rolloff in the upmost 1/2 octave of the audio band.
      Good, no unnatural pre-ringing, natural transients.
      Very few.
      Best separation of percussive high frequency instruments, e.g. hihats and shakers. Best ambience definition.
      Due to better impulses, subjectively more treble content than “Sharp”.
      SD LD Filter (ESS):
      Very little rolloff in the upmost 1/2 octave of the audio band, cutoff a little earlier (19 instead of 20 kHz), very good transition from passband (audio) to stopband (above audio).
      Good, almost no unnatural pre-ringing, natural transients.
      None! Even better than Sharp Filter.
      Best “Black Background”.
      “Transparent” feel.
      Obviously (for me) best compromise between frequency response, transient response and aliasing artifacts (none!).
      A good replacement of the AKM Slow Filter, as the ESS Slow is different and not that good.
      Just for fun, NOS Filters, (AKM and ESS):
      • No compromise perfect impulse response, on cost of all other important parameters.
      • Clearly audible aliasing artifacts overshade everything, sounds like something is broken.
      Thank you KaiS for your response.
      You write "In short (@ 44.1 and 48 kHz sample rates only, irrelevant for higher SRs......)
      Question:
      1. Does this mean, that the Slow filter kicks in at sample rates of 22.05 kHz upwards and 24 kHz upwards only?
      2. Or does it relate to your SQ impressions @44.1 and 48 kHz sample rates?
      Assume that the sample rate is 96kHz, does it mean that the Slow filter kicks in @48 kHz upwards?
      Question:
      Refer to chapters 34.13 and 34.14 of the manual. The graphs are self-explanatory.
      Graph 34.13 applies to AD filters, not DA Filters
      Graph 34.14 does not respond to my question.
      your response is a killing phrase.
      I wasn't saying they were. I was implying that looking at these graphs could help you understand how different reconstruction filters affect the frequency response of a converter and why it's better to shift their effect on the FR outside of the audible range. Apparently I was wrong.
      Again, ChatGPT gave me the answer, I was looking for.
      This was my prompt:
      MY RME DAC has an DA Filter SD Sharp, which filters from about 20 kHz upwards with sample ratels of 44.1 Khz and 48 kHz. However, when the sample rate is for instance 92 kHZ, does the SD Sharp Filter filter from 48 kHz upwards?
      ChatGPT
      The behavior of the SD Sharp filter in your RME DAC changes with different sample rates. Here's a more detailed explanation:
      At 44.1 kHz and 48 kHz sample rates: The SD Sharp filter begins to filter from around 20 kHz upwards. This is because these sample rates are typically used for standard audio playback, where the audio content is within the human hearing range (up to 20 kHz), and the filter helps to remove frequencies beyond this range to avoid aliasing and other artifacts.
      At higher sample rates (e.g., 96 kHz): The filtering behavior of the SD Sharp filter will scale with the sample rate. For a sample rate of 96 kHz, the filter cutoff point will move up proportionally. Specifically, the filter will start attenuating frequencies above approximately half the sample rate. In the case of 96 kHz, this would be around 48 kHz.
      So, to answer your question: Yes, when the sample rate is 96 kHz, the SD Sharp filter will start filtering from around 48 kHz upwards. This scaling ensures that the filter continues to remove unwanted frequencies and noise that are above the audible range and could cause issues with digital audio processing.
      It makes no sense to bring the answers from KI tools into discussions. Trust the real experts instead. I have asked the AI in areas I know a lot about on a trial basis and the quality of the answers is just scary.
      Think about it, the AI is fed with so much data, who knows where it all comes from and no one can tell me that something like quality could be ensured with so much different data and data sources. You can also see it in the quality of the answers. Some things may be true, others not. As in many areas, “shit in, shit out”.
      Ramses, thank you for your response.
      Does your answer contradict the ChatGPT's response? If your advise is to listen to the real experts, why don't your respond to my one and only simple question? I am very much open to accept responses from experts, to which you are considered one of them by me.
      I just asked that one question, to which only ChatGPT gave me a plausible answer. Just, tell me that the response of ChatGPT is non-sense and please inform me what the correct answer is from an expert.
