See handbook chapter 16. Up to three devices as aggregate device seem to be supported.
16. Using more than one Digiface USB
OS X supports the usage of more than one audio device within an audio software. This is done
via the Core Audio function Aggregate Devices, which allows to combine several devices into
one. All units have to be in sync, i.e. have to receive valid sync information via a digital input
signal.
• If one of the devices is set to clock mode Master, all others have to be set to clock mode
Slave, and have to be synced from the master by feeding ADAT or SPDIF. The clock
modes of all units have to be set up correctly in their Settings dialog.
• If all units are fed with a synchronous clock, i.e. all units show Sync in their Settings dialog,
all channels can be used at once.
Note: TotalMix is part of the hardware of each device. Up to three mixers are available, but
these are separated and can't interchange data. Therefore a global mixer for all units is not
possible.
