1 (edited by Chimera1to1 2019-08-13 14:27:03)
Topic: possible TotalMix FX /Logic problem
I had my Fireface 802 working perfectly with my new Mac until I allowed the system to run updates. Since the update Logic is not routing the audio through to the Software Playback in TM FX. The meters in Logic show the sound and the initial input shows in TM under Hardware Inputs but the sound isn't routing to my monitors as it normally does. I'm also getting the following error message.
Mismatch detected - Channel and FX settings of Device and Totalmix are different.
Click Yes to use the Totalmix settings (default)
Click No to upload the Devices' settings into Totalmix.
Clicking Yes or No does not solve the issues.
Spoken to Apple support and they are suggesting a full reinstall of the O/S. I've updated and reinstalled TM FX, USB driver and 802 firmware.
Any ideas?
Re: possible TotalMix FX /Logic problem
The solution  - seems to be some form of corruption of the Logic project file. Opened another project and everything works as it should. Well that's 2 days I'll never get back.
