Topic: HDSPe AIO sound issues
I'm having sound issues with my brand new HDSPe AIO. When Foobar2000 ( with Asio64 or Kernel Streaming) runs tracks above 96khz, the sound is crackling ( same as LP's ). And when the volume slider is at -100db I can hear noise.
The sound card is plugged on a PCI-E X1 port. DIY XLR cables ( Belden 1800F with Neutrik connectors ) are used with the balanced analog breakout cable ( BO9632XLRMKH ). These cables were connected to my old HDSP 9632 without sound issues.
- My new hardware is: Asus Crosshair VIII ( X570 chipset ) + Ryzen 3700x.
- OS is Windows 10 v.1903.
- The HDSPe AIO is selected as default ( Analog 1+2 )
- Windows system sounds are shutted down.
In Foobar, i've tried to change the outpout from Asio to KS but the problem remains. To solve the problem I have to use the SOX resampler ...
I suspect compatibility problem with the AMD X570 chipset drivers ...
Need help please. Thanks.
