Topic: FF802 AES/EBU output to Genelecs
Hi!
I just don't understand what I'm doing wrong.
I have two Genelec 1032C's daisy chained digitally and connected to FF802 AES/EBU output with a digital XLR cable. The Genelec GLM works nicely but shows no digital audio input.
I played music via AN 1/2 which I sent to AES. Main Out is assigned to AES and its meters show action.
I tested the cables and they are ok.
Any ideas?
Re: FF802 AES/EBU output to Genelecs
Settings dialog, AES set to 'Professional'?
Yes.
Analog audio works so the speakers are ok.  Brand new.
Something wrong in the 802 settings..
You can check the FF802 output and your cable: Connect FF802 AES out to FF802 AES in. Do you see signal in the top row of TotalMix FX, AES channel?
If not, go to Options > Reset Mix > Total Reset and try creating this Playback 1/2 to AES Out routing again.
Total Reset helped! THANK YOU!!!
