Topic: Bug? AES out mute not working
I assigned Main Out to AES and the M button doesn't mute the signal to speakers. Maybe a bug in the application?
RME User Forum → TotalMix FX → Bug? AES out mute not working
Which TM FX version ?
Which mute button did you press ? Of what channel exactly ?
Are you perhaps in submix mode and selected the wrong submix / HW output ?
1.61
I pressed Main Out mute button.
The same problem with AN 1/2 which is sending signal to Main Out (AES).
These channels' faders work normally.
I tried submix and free routing modes.
Hopefully there is a fix for this. I use the Main Out mute all the time because I want to silence the speakers quickly when recording with headphones.
There is a master control for Mute, Solo and Fader groups on/off, in the top right corner of TMFX (under the FX meter). Please check that Mute is enabled globally.
That was it Jeff!! The master mute...
My mistake No bug!!
