Topic: Fireface UFX with 2 Focusrite Clarett Octopre ADAT link up issues
Hi Gang!
I'm using a Fireface UFX with a pair of Focusrite Claretts connected to ADAT, but for some reason can't get audio out of the Claretts.
I can get Audio in O.K. as I have my desk's record bus connected to the second Clarret which records O.K.
I'm using Logic as my DAW, and although it shows I have 30 output channels available, I can only get audio out of the first 8 of my UFX. If I select any of the other outputs I can see the signal on the front panel of the UFX (in the ADAT section), but no corresponding flashing lights (or sound) on the Clarrets (incidentally, the input does flash on the Clarret and the corresponding ADAT input channel on the UFX when I record).
Everything seems to be working in Totalmix as well (which is usually the place I find myself tripping myself up with this kind of thing). I can see the channels pumping, and turned up, but still nothing on the Claretts.
I can't for the life of me work out what's going wrong, anyone got any suggestions?.
Thanks in advance.
