Topic: Totalmix signal Failure - Fireface UFX / 802
Hi There,
I'm getting a recurrent problem while trying to connect my computer to a studio Fireface. I've already tried in a couple of different studios, in which there are used either a Fireface UFX and Fireface 802, and both times I've got the same problem, which is the sound not syncing correctly as I open Totalmix. Instead of coming the clear signal, I get a weird crashing sound, which happens either for spotify/daw/etc. I used to have normal connection, and the problem started suddenly around a month ago. Already tried changing sample rate/midi connection/reinstalling drivers/etc and nothing really worked out. Other people that work in the studio don't have the same problem.
Would anyone know what could be a possible problem/solution? That would be of a HUGE help.
Thank you very much in advance.
_
MacBook Pro 2017 + OSX Mojave
Re: Totalmix signal Failure - Fireface UFX / 802
please provide more details about the OS version, driver installed etc.
