Sounds good!
Thx for the continuous involvement in developping DigiCheck, a tool that it's crime to forget :-)
I guess it is important to figure out the change from stereo to multichannel instances, where the sound focus no longer stands up front along a line, but rather more moves to the centre point of the speakers setup
That way, the overlapping of sound emission from multiple sources becomes crucial and makes the analysis even more complicated than simply considering 5,6 channels instead of 2
Projecting the sound loudnesses from above is for me the useful and natural vision to complete the work of listening, the latter being largely influenced by the monitoring setup quality, room acoustics
Thus to help keep neutral against those uncertainities, the newest tool "surround audio scope" is the one I feed back preferably
A set of suggestions now:
1) The sonic distribution around the listener being similar to the microphone sensivity against random field patterns, I suggest to rename the grahical spot
MultiPolar scope
a way to identify the brand's ultimate tool
I guess that many audio engineers would feel it cool and of natural sense
2) the LFE channel carrying a limited low range of audio components, and the sound field from subs being of plane wave type in mid sized rooms, I propose to plot it as separate in the graphics, by mean of an expanding circle from the centre point to the outer circle line (calibrated to 0 dBfs), see below
LFE plot example
for the multichannel draft peripheral line, allow the user to select the grahic dynamic range from centre point to max range between linear and compressed plotting (such like meters) and the range of audio between 6 and 60 dB say
That way, we can correctly plot sounds patterns showing low or high loudnesses variance across channels according to the audio material
3) make use of LeqC instead of B, more useful against various measuring protocols in acoustics
4) be prepared to add two more channels, in total 8 quarters graphic map available, to support users having multiple mics distributed around a machinery or public address speakers array for instance, and 8 is a magic number in audio you know...:-D
5) a request for the setting basics, see here
settings screen shot
Now a question about the global recorder: what is the mean of the two new buttons M and S?
as it becomes active once the record completed, just before to save the files
I'll continue to make some tests now on..
Best regards
HDSP 9632, Octamic D, Head Acoustics, WL6, NVH software tools
