Topic: Can I switch between two different outputs via button on the DAC?
I have studio monitors connected via XLR, and a separate headphone amp via phono.
I don't use them both at once.
I haven't found a way to change the outputs to only one or the other, so I have to power down the monitors when listening to headphones. Is there a way to do this automatically (like there is with the built in headphone out?) I'd like to be able to press a button to switch.
Even better, I'd also like the volume output level to be different for each of the outputs?
Is this possible?
(Apologies if this has been asked before - I've had a check of the forum (and the manual), but haven't been able to locate an answer.)
Re: Can I switch between two different outputs via button on the DAC?
On my ADI-2 Pro FS BE I can toggle between phones and speakers by using a remapped key on the front...
See my blog article: https://www.tonstudio-forum.de/blog/ind … our-Setup/
3
XLR and RCA use the same mute control, independent mute is not possible.
Thanks for letting me  know. I'll stick with simply powering down the monitors when I want to listen on headphones.
Or you can plug your headphone amp with the TRS on the front, and as Ramses said toggle between line out and TRS with a key on the front or with the remote smile
Does it matter if I have two amps hooked up to the outputs of the RME DAC, one via XLR and one via RCA jacks? I was also curious if I could select one output. Given we can't, does it matter if two devices are hooked up?
7
The outputs have their own driver stages, so no problem to use both.
Many thanks smile
