Topic: ARC Speaker B Volume Control
Okay, I have forgotten more than I can remember!
I had to reset a few things. Now when I switch to Speaker B I can only control the volume using TM. I believe this used to work with the dial. It only does the Mains now. Can someone remind me?
Re: ARC Speaker B Volume Control
On TotalMix FX Speaker B channel, you have to activate the LINK button to link to Main fader.
Thanks. This links Speaker B to my Main output,moving both volumes at the same time. I am pretty sure I had independent control before I screwed up my settings.
FYI - I have my Main output assigned to AES and my Speak B to AN1/2. I only want AN1/2 to respond to the scroll wheel  when Speaker B is engaged.
No way, it works like that, with Link active..
