1 (edited by ukraine.vinyls 2020-04-27 13:57:31)
Topic: Problem with RME Fireface UFX II
Hello there. I have a problem with my new RME Fireface UFX II
I already install the last official drivers, but the lamp HOST Led is yellow.
I connected my drum-machine to 5/6 Analogue Channel in the cart, but the sound very distorted. Look this video please:
https://www.youtube.com/watch?v=L5PEQJs … e=youtu.be
2 (edited by ukraine.vinyls 2020-04-27 13:57:57)
Re: Problem with RME Fireface UFX II
Another screenshot
https://prnt.sc/s6qxqi
Please provide more details about the hardware and software setup.
4 (edited by lucasheight 2020-04-29 03:56:31)
Sounds very similar to the problem I have with a new ufx ii. In my case it appears to related to USB and the laptop keyboard. Also not getting any advice here which is a bit disappointing.
forum.rme-audio.de/viewtopic.php?id=30527
OS Name    Microsoft Windows 10 Pro 64-Bit
Version   10.0.17134 Build 17134
Other OS Description     Not Available
OS Manufacturer    Microsoft Corporation
System Manufacturer   Gigabyte Technology Co., Ltd.
System Model    Z390 AORUS MASTER
System Type    x64-based PC
System SKU    Default string
Processor   Intel Core i9-9900K CPU @ 3.60GHz, 8 Core(s), 8 Logical Processor(s)
BIOS Version/Date    American Megatrends Inc. F8, 14.03.2019
SMBIOS Version    3.1
Embedded Controller Version    255.255
BIOS Mode    UEFI
BaseBoard Manufacturer    Gigabyte Technology Co., Ltd.
BaseBoard Product    Z390 AORUS MASTER
BaseBoard Version    Mainboard
Platform Role    Desktop
Secure Boot State    Off
PCR7 Configuration    no binding
Windows Directory    C:\WINDOWS
System Directory    C:\WINDOWS\system32
Boot Device    \Device\HarddiskVolume1
Locale    Ukraine
Hardware Abstraction Layer    Version = "10.0.17134.1"
Username    lan\User
Time Zone    Eastern Europe
Installed Physical Memory (RAM)    16.0 GB
Total Physical Memory    15.9 GB
Available Physical Memory    10.2 GB
Total Virtual Memory    18.3 GB
Available Virtual Memory    11.1 GB
Page File Space    2.38 GB
Page File    C:\pagefile.sys
Kernel DMA Protection    Off
Virtualisation-based security    Not enabled
Device Encryption Support   Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Securuty Test Interface failed and device is not InstantGo,  Un-allowed DMA capable bus/device(s) detected
Hyper-V - VM Monitor Mode Extensions    Yes
Hyper-V - Second Level Address Translation Extensions    Yes
Hyper-V - Virtualisation Enabled in Firmware    Yes
Hyper-V - Data Execution Protection    Yes
Also, I'm using Ableton 10.1.9, Asio MADIface USB, RME Fireface UFX II
Screen https://prnt.sc/s7xj7x
Screenshot https://prnt.sc/s7xoir of TotalMix FX when i send/rec Ableton channel - sound like being played through a ring modulator(
We have the same problem, Bro.
I make new short Video with my problem. Look it please.
https://youtu.be/WVDjPlkiLFU
Yes it appears like the same problem I have. Have you tried different USB ports on the computer.?
I found a solution and it helped me! In MADIface Series Settings / WDM Devices / Configure - removed all channels, after check your Ableton smile
unfortunately this made no difference with my set up.:(
